Click here to tell us about your new email address
BeoRemote One BT
This post has 12 Replies | 1 Follower
jans
Belgium
Posts 251
jans Posted: Mon, Jan 30 2017 8:53 PM
Hello
Does anyone know if there is a way to upgrade the sofware of a BEO remote BT? I looked around on the internet but couldn't find much.
Where can I find info about recent software updates, if any.
Regards
Jan
zerocool143
Posts 42
It will be updated once the TV got updates.
jans
Belgium
Posts 251
jans replied on Tue, Jan 31 2017 7:09 AM
So everything will go through the TV? Will you, as an owner be able to decide whether or not you want to do this?
Do you know if there have already been such updates in the past?
Regards
Jan
Chris
Ostend-BE
Posts 1,114
This is my version, I wonder if it is the latest?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
zerocool143
Posts 42
The latest version of software for the tv is V0.2.1.22
Just check your TV if it has the same version.
Keith Saunders
Little Ann, Hampshire, United Kingdom
Posts 4,808
The latest and current software version is 2.7.16 so you are up to date..
Regards Keith....
Keith Saunders
Posts 4,808
The BeoRemote One BT software will be updated automatically via the Bluetooth connection from the TV.
The update starts when the TV is switched to standby.
You will be able to see the update progress in the display of the BeoRemote One BT when it happens.
After the installation of new software, the BeoRemote One BT will reboot for 30 seconds and then will show the Bang & Olufsen logo.
If you have other BeoRemote One BT remotes then you need to switch the TV on and then off with that additional remote for it to be updated as well.
Regards Keith....
jans
Belgium
Posts 251
jans replied on Tue, Jan 31 2017 8:34 AM
Keith
Very clear info! Thanks for the feedback
Jan
jans
Belgium
Posts 251
jans replied on Tue, Jan 31 2017 9:34 PM
Keith Saunders:
Regards Keith....
Keith
I managed to go into the service screen. It says version 2.7.9. So probably not the latest version. Can I update the software myself? I have a V1 so update over BT won't work.
Jan
Chris
Ostend-BE
Posts 1,114
Chris replied on Wed, Feb 1 2017 1:17 PM
Keith Saunders:
Nice... Thanks Keith
Millemissen
Flensborg, Denmark
Posts 8,942
You'd probably have to take it to someone, who has one of the Android based BV's and connect it to this in bluetooth mode.
But you'd gain nothing, I guess - since you will continue to use it in ir-mode with the V1 afterwards.
BeoNinja
Posts 14
BeoNinja replied on Mon, Feb 13 2017 12:20 AM
The newest version should be 2.7.24
ThatGuyFromDenmark
Posts 21
How do you check the software version on the BT remote?
Page 1 of 1 (13 items) | RSS
