Click here to tell us about your new email address
BeoRemote One BT functions, tips, tricks?
This post has 24 Replies | 4 Followers
alex_112
Posts 22
alex_112 Posted: Sun, Jan 8 2017 1:13 AM
Hi!
I just added a BROne to my collection of loved items and it currently seems to be competing for the love from the BeoTime flute by just looking at it :-)
After a few hours playing with it (BR1), I've got it working fine with IR: Lights, BeoSound Moment. Via BT fine with: Android, *not* fine via BT: BeoPlay A6, that's about how far I've come.
I read at a couple of places it works with non-B&O IR, any tips on how to get it working with non-B&O gear?
What are you using this beautiful piece with? Discuss! ;-)
Best Regards. Top picks: Beogram 3000 tangential, Moment, Essence, Beo6, BROneBT, BeoTime, LC2, BeoSystem 3+ML/NL, BeoLab 11+7-1+8000+4000, Passive+CX100+Cona, Passive+CX50+Cona, BeoPlay A6, H3/H8
Millemissen
Flensborg, Denmark
Posts 9,039
ONLINE
I guess you mean the BROne/BT version!
'Lights with IR' ---- how many 'klicks' do you need for that?
alex_112
Posts 22
alex_112 replied on Sun, Jan 8 2017 11:55 AM
Yes, BeoRemote One with Bluetooth.
Depends what our need but one to get into lights, one or more for control. You also have favorite buttons with are mappable. Haven't gotten "all off" working with long press power button for lights.
BR
  //Alex
9 LEE
Eastbourne, UK
Posts 6,350
9 LEE replied on Sun, Jan 8 2017 1:22 PM
Seeing as this remote is going to be around for a while, and is versatile, would it be worth having a sub-forum dedicated to it?
We did it with the Beo5/Beo6, which seemed to go down well.
Only a thought....
Lee
Millemissen
Flensborg, Denmark
Posts 9,039
ONLINE
alex_112:
BR
  //Alex
Does that mean, that you can map 'Light' to one of the MyButtons?
Untill now noone on the forum has confirmed that?
Millemissen
Flensborg, Denmark
Posts 9,039
ONLINE
I am with Lee on that thought.
Only remember to include BT in the remote name, if the sub-forum will be created.
PhilLondon
London
Posts 3,551
Millemissen:
With the non BT version, you can.
Beoworld app with direct photo upload and emoticons. Other apps: ConsltThe Story Mouse
alex_112
Posts 22
With the BT version as well.
mr_anders_son
sweden
Posts 1,450
alex_112:
How?
BeoVision 14-55 oak...BeoLab 8002 as FRONT....BeoLab 4000 as REAR....BL19 SUB copper 90's edt....BV5 2xHDMI....BV7-32 MK3....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...A2 Black Copper Special Edt
Millemissen
Flensborg, Denmark
Posts 9,039
ONLINE
alex_112:
Thanks!
Now - when we get the sub-forum ;-) - maybe you could make a small 'howto-guide'.
There are still some users with 'old' LC1/2, who have been used to push the Light button and a digit.
(As well as those who control their light in a more modern way - using the gateway).
Is that possible, when you have configured one of the MyButtons for Light
alex_112
Posts 22
LIST -> Settings -> Buttons -> <Button> -> <Function (i.e. Lights)>
PhilLondon
London
Posts 3,551
One thing that doesn't work for me is addressing individual lamps.
With the Beo4 you'd press LIST until LAMP appears, and then press 1 to address the first lamp.
Here you can access the LAMP function from the list but it sends the LIGHT code rather than the LAMP code!!
They told me it was a known bug in the firmware. I got it flashed with a new one and it still doesn't work :-(
sq2002
Posts 53
sq2002 replied on Sun, Jan 8 2017 7:42 PM
On the BT version (the one I have ) it does not work that way...
I still haven't found am easy way to control light.
Millemissen
Flensborg, Denmark
Posts 9,039
ONLINE
sq2002:
It seems that alex_112   has - hmmm?
riverstyx
Exeter, Devon, UK
Posts 885
For those of you with a BeoRemote One BT and an android phone, you can pair them and use the remote to navigate around the menus on your phone - pretty pointless, but fun to try Smile
Millemissen
Flensborg, Denmark
Posts 9,039
ONLINE
PhilLondon:
Personally I could live without that.
As long as I would be able to adress my light scenarios (I use mostly 4-5 as a combination of 4 individual lamps) and dimm/increase these with ease, I'd be fine.
P.S. But if there is a bug there, they ought to get it fixed.
alex_112
Posts 22
alex_112 replied on Sun, Jan 8 2017 10:49 PM
Any idea of usage with third party products? I can see blinds etc under "Control", is there a compatibility list?
PhilLondon
London
Posts 3,551
These commands are passed to a BLGW if you have one, then the BLGW will command the blinds or any device. The remote does not control things directly .
alex_112
Posts 22
alex_112 replied on Sun, Jan 8 2017 11:03 PM
So this "455 kHz for Bang & Olufsen products and 20-80 kHz for third party non-A/V product control" is not actually the remote which sends but rather the BLGW IR-transceiver? Or is it something else that's the 20-80 kHz?
sq2002
Posts 53
sq2002 replied on Mon, Jan 9 2017 12:27 PM
If someone can show me how to configure the light function into a MyButton I would be very grateful Smile
You have to switch now from bluetooth to IR, lot's of steps to control the light. After that, you have to go back again all the steps to switch to bluetooth (TV function) again. Not easy, and very clumpsy..
Hiort
Sweden
Posts 1,339
Hiort replied on Mon, Jan 9 2017 1:07 PM
sq2002:
I´m quite sure the only thing you can do is to associate the LIGHT command to a MyButton. Nothing more. That is the way I have arranged it. So rather than pressing LIST and go down the list to LIGHT I can press a MyButton.
Ideally I would like to configure certain light scenes to a MyButton but that is not possible. One would need a BLGW for that.
Hiort
Sweden
Posts 1,339
Hiort replied on Mon, Jan 9 2017 1:11 PM
Millemissen:
PhilLondon:
@MM
How do you access the light scenarios using the BROne?
/C
PhilLondon
London
Posts 3,551
Hiort:
LIGHT + Digit, if you've got LC2s... There are some scenes you can use as well like Leaving, etc... if you've got a BLGW.
sq2002
Posts 53
sq2002 replied on Mon, Jan 9 2017 2:39 PM
Mybutton and Light : standard the remote starts in bluetooth mode.
can you please show me step-by-step how you programm the light on Mybutton, because as far as I see it you can store it because you need to switch from BT to IR. Mybutton can only store the last 3 steps ??
mybutton + number would be good enough,
but after that you also would need a mybutton to get back to BT
Hiort
Sweden
Posts 1,339
Hiort replied on Mon, Jan 9 2017 3:51 PM
sq2002:
Sorry, I have only the regular BRone
Page 1 of 1 (25 items) | RSS
