Beovox S75 Capacitor List
Not Answered This post has 0 verified answers | 11 Replies | 0 Followers
delroy
Silver Member
delroy posted on Sun, Oct 16 2016 8:21 PM
I recently purchased a pair of S75 and I would like to change the capacitors however I am having trouble finding out what capacitors I would have to buy.
  • 47uf 40v
  • 47uf 40v
  • 10uf 40v
  • 2,2uf 250v
  • 33uf 40v
  • 12uf 40v
  • 3,3uf 40v
I am pretty sure these are the capacitors that are on the crossover I am however not completely sure. I also don't know if these are polarized or all bipolar capacitors.
If anybody knows a bit more about the capacitors I would much appreciate some input.
Dillen
Copenhagen / Denmark
Dillen replied on Sun, Oct 16 2016 8:50 PM
Welcome to Beoworld !
Capacitor kits are readily available for most Beovox models, including Beovox S75.
The kits contain correct components, values and types and comes with a detailed component location chart.
Email or PM me.
delroy
Silver Member
delroy replied on Sun, Oct 16 2016 9:02 PM
Thanks for the reply, I would like to just buy a kit however I am on a pretty tight budget for now and would like to at least get the S75 in working order. I really just need to know if the capacitors are all bipolar or can all be replaced with bipolar capacitors. I am pretty sure that a lot of the original aren't bipolar however when I read a few topics on this site I get the idea that they are all bipolar. So that is why I am asking.
Dillen
Dillen replied on Mon, Oct 17 2016 7:08 AM
Grabbing a kit is often cheaper than finding and buying the components separately.
All caps in your filters are axial, bipolar electrolytics (the speaker lead signal is AC).
Make sure to get capacitors of a decent quality, meant for crossover applications and preferably 100V types.
Vanlierde
Hello, i've just bought a pair of s75 without crossovers but with good speakers. I'd like to restore them, but i can't find the crossovers schema.
More, could you please tell me how much would cost me one of your complete kits for that?
Thank you !
Dillen
Dillen replied on Sun, Nov 5 2017 12:34 PM
Are the filter boards missing?
Vanlierde
Yeah, it doesn't remain anything.
Dillen
I suggest you look for a pair of original filter boards before thinking about the capacitors.
Caps is the easy part. There are many other components on those boards besides caps.
Vanlierde
Thanks for the advice. By luck, I just found the schema, but i'm not sure between the tweeter and the dome medium. Could you please tell me who is who? I try to insert a picture...
Vanlierde
Vanlierde
Vanlierde
No way! Could you please tell me the colors of the wires on each speaker? It would be agreat help...Big Smile
Page 1 of 1 (12 items) | RSS
