Click here to tell us about your new email address
Beovox Penta Restoration Project
This post has 9 Replies | 3 Followers
niston
Posts 4
Silver Member
niston Posted: Wed, May 18 2016 7:58 AM
Hi all,
Some pictures from my (unexpected) Beovox Penta restoration project:
What they looked like when I got them.
Well known problem, I think. For increased difficulty level, two of them midranges were completely shot (open voice coil).
Purists and haters will hate, but I think those drivers work absolutely great. You are invited to visit Switzerland and listen carefully, if you are not a believer yet. The connector is a high current automotive type (interlocking on connection).
New 2.5mm2 wiring for the bass drivers, connected up in a star topology, instead of the original daisy chaining through what appeared to be 0.75mm2 wires, across dozens of spade connectors.
Crossovers needed total recapping and some tuning for the new midranges.
Simulation & lots of trial listening used to find ideal configuration.
All done and set up. If you must know: The display is a 56" Philips Cinema 21:9 screen.
The once presumably copper colored deco stripes had become...ugly.
Redid them in glossy, dark metallic red to match my living room interior. Other plastic parts were painted maté black.
30 year old preciousssssss, in all new and shiny glory!
There's more info on my blog. Not sure if may link here, just google for "niston cloud".
Saint Beogrowler
Saint Paul, Minnesota
Posts 335
Sure look awesome with the black accents and red trim.
Peter-
Lee
Newcastle upon Tyne UK
Posts 689
Silver Member
Lee replied on Thu, May 19 2016 9:33 AM
Absolutely fantastic work!!
Could you post the replacement driver details and the new resistor values please so others (possibly myself Smile) could do the same.
Also what do you mean by wired in a star config? Is that the same as wired in parallel? And if it is how did you manage to attach all those wires to the crossover boards?
Lee
Beobuddy
Utrecht, The Netherlands
Posts 3,142
Beobuddy replied on Sat, May 21 2016 3:10 PM
Some points I wonder:
You're decreasing R3 on board 14 from 1.8 to zero ohm. At the same time you're increasing C4 from 2,2uF to 4,7uF?
That means that you're shifting more energy to the tweeter with a bigger frequency range at the bottom with more lower frequencies.
Is it neccessary to lower the crossover frequency of the tweeter? Limited range of the mids
Be carefull with turning up the volume Big Smile
On the mid board 15 you're also decreasing R1 from 2,2 (older boards have 3.3. depends on tweeter used) to 0.68 ohm. If have already had several boards from customers with a burned coil L3. So, the same counts here, you're allowing more power to the mids, but it has to pass L3.
niston
Posts 4
Silver Member
niston replied on Sun, May 22 2016 2:43 AM
Sorry the schematic in the photo above is somewhat unclear.
First, I scribbled the original value if R1 on it, as actually found on my PCBs (I checked against different schematic versions). Second, I wrote some recommendations by DieBogener (I believe, IIRC - not sure). The new resistor values are finally written with the computer (as opposed to the other hand written stuff). I should probably have photographed a nicer schematic!
I didn't actually follow the recommendation and change C4 in the tweeter circuit, because as Beobuddy suggests, that'd lower the crossover point for the tweeter, which I don't think is useful. If anything, I would actually have liked to try and shift the crossover point for the midranges upwards, so that they'd reach a bit higher. The new drivers could theoretically do quite well up to 9kHz, although because of the line array arrangement,very  much above (specified) 5kHz would probably not be a good idea. In any case, I don't think it really can be done without changing L3 on the midrange board; At least I couldn't do it in XSim.
The modifications to the midrange PCB are 0.68Ohm instead of 2.2 Ohm for R1, because replacement drivers have supposedly (listening, driver data sheet) a tad bit lower efficiency than the originals. According to XSim, 1.4Ohm would have been the optimum value for R1, because lower values seem to create a peak around 2400Hz in the simulation. Listening to both, I however found that I preferred the 0.68Ohm configuration.
One thing to note about my simulations is, I have no data whatsoever (except DC resistance) on the original drivers, so ran simulations with flat 4Ohm drivers. Thus, the simulations are really nothing more but extremely rough approximations!  I still found them useful to get an idea of how the crossovers work and what might actually help to attain desired changes, before soldering and listening.
I've also changed the 6.8 Ohm resistors in the boucherot circuits (R3, R4 on midrange PCB) to 7.5Ohms, roughly twice a new driver's DC resistance (measured 3.7Ohm). Something I have not done so far is adapt C6/C7 to the new voice coil inductance. Not sure if I ever will, Im happy with the midranges. If I'm gonna change something at all, it'll be reviewing the 0Ohm in the tweeter circuit.
The new drivers are Visaton FRS8 (4 Ohms). They need a bit of mechanical trimming to fit; I used metal shears which worked a treat. The surrounds have sort of a ring around them on the front. Pay close attention as not to damage it while trimming (I ruined one driver like this). Conveniently, the original driver mountings can be reused for these drivers. It's advisable to have some kind of o-ring between driver and assembly though, as there might result an open sub-millimeter gap between driver chassis and assembly panel, probably when the trimming is not done "round" enough or something. For me, this was a non-issue, my pentas still had (the supposedly original) o-rings. My coworker found it to be a problem though, the o-rings in his pentas had mostly disintegrated.
Considering burnt coils, he had one completely fried (deep brown and crispy) L3, even though the crossovers in his beolab pentas had a 3.3Ohm R1. Interestingly, also L6 on both bass/tweeter boards had ... somewhat deteriorated:
Those L6s were both replaced with iron core versions (didn't find air core ones that large, but they're not located in a signal path anyways), together with the L3s (including the non-burnt one).
Also checked his amplifiers for DC offset and found nothing above few millivolts. I have no idea what happened there. The coils themselfes weren't burnt, also their lower ends still stuck firmy to the PCBs. I somehow doubt that heating of the large coil (located below L6 when mounted) caused this. Maybe it was heat from the amplifiers during heavy duty use? They didn't produce much heat when I had them here for testing, but who knows what the previous owner used them for.
My beovox pentas on the other hand had originally a 2.2Ohm R1 and no coil related problems at all. I'm running those pentas on an Onkyo TX-NR838 with quite a bit of oomph at times, so will probably re-check the L3s after a while and, if burnt or even just preemptively, replace them with suitable air core inductors from intertechnik (they have a somewhat thicker wire). Those inductors are actually not that expensive either, much unlike replacements for the big transformer core coils.
Concerning the "star topology" wiring: The original wiring for the bass drivers is done daisy-chain style; There's a spade connector on the PCB, it has the red wire running to the first driver. The driver actually has two spade connectors per wire color; the wire coming from the xover PCB connects to one of them. The other same-color spade connector has the wire running to the next driver and so forth and so on. This means that the signal arriving at the topmost driver will have passed through a lot of thin wires and (proably even worse) spade connectors. Same applies to the return path (black wire).
I used some high power (32A@230VAC rated) clamping blocks and ran one short 2.5mm2 wire per color (black / red) from the xover PCB to each clamping block. Then, there's 4 seperate 2.5mm2 wires per color running from the clamping blocks to each of the drivers, so that the signal is not looped through numerous spade connectors anymore. In effect, there's two wires per driver now, for the runs along the enclosure.
It shall be noted here that I used absolutely no audiophoolerish $5k/meter speaker wires or somesuch, just regular 2.5mm2 (14AWG) copper speaker wire from what might just as well be home depot. The replacement caps were not super-duper-expensive-copper-tin-silver-unobtainium caps either, but just solid 100V MKT types from Audyn/Intertechnik.
On a side note, maybe the looping-though-bazillions-of-spade-connectors thing is why some people who've done it swear that rewiring makes such a big difference with the pentas. I myself have done it just because I think its good engineering practice to minimize resistance in (relatively) high power paths, while implementing it doesn't cost an arm and a leg either. I'd also not entirely dismiss the notion that, maybe, the bass sounds even dryer and more controlled now than it did before. Big Smile
niston
Posts 4
Silver Member
niston replied on Sun, May 22 2016 6:24 AM
Here are some XSim graphs. As noted above, the Y axis values have no absolute meaning and can only be used in relation to each other and only among the same type of PCB drivers (midranges or woofers or tweeter). Concerning the tweeters, does somebody here happen to know more about them, and/or what influence the mounting baffle has on efficiency in particular?
Lee
Posts 689
Silver Member
Lee replied on Tue, May 24 2016 12:26 AM
Thanks for all the information :-)
Beobuddy how can you tell which tweeters you have? I managed to blow both of my original ones (early pair of Beovox Pentas) so they were replaced and now I'm concerned they are the later types that need a different resistor.
niston
Posts 4
Silver Member
niston replied on Wed, May 25 2016 5:14 PM
On another side note about the sometimes found "SEL" drivers: SEL stands for "Standard Elektrik Lorenz",a German manufacturer that was acquired by ITT in 1930. The brand name remained until the late 80s/early 90s, if memory serves me right.
Professor David A Flynn JP
Belfast, Northern Ireland
Posts 116
Hello just think your Penta's are looking beautiful, I have a set as well working with my Beosystem 5500 in my drawing room, the sound is amazing.  My vinyl collection has been enhanced by using these speakers.  The crispness of sound linked using the Beogram 5500 turntable is brilliant.  My visitors are all pleasantly surprised at the sound.
Wish you all the best with these speakers.
Best regards
Whistle
Professor David A Flynn JP LM
Big Smile
BEOVOX141
Denmark, West
Posts 174
The Penta.. Smile
Allthough from a time long gone,- they really are forever....
Page 1 of 1 (10 items) | RSS
