Silent Gliss Curtain track
Not Answered This post has 0 verified answers | 7 Replies | 2 Followers
Seanie_230
UK
Seanie_230 posted on Mon, Mar 14 2016 4:45 PM
hello lovely people
So i have a question
I have a Silent Gliss curtain track which responds to IR or a Button press to open and close.
I also have a BLGW.
How can I interface the Silent Gliss track with my BLGW? i Want to be able to use my Beoremote One to say curtains close or open, the BV7 receives the commend and sends it to the BLGW and then the macro on the gatway triggars a commend to the Silent Gliss track.
Question is how to interface with the track.
Any Idea's
Thanks All
BLGW - Rekindling the love of ML
mjmedlo
The question is whether or not it can be controlled via ip.
beoandy
sissi not kangaroo
hi! look at this:
Global Cache iTach IP2IR
This driver supports communication with a Global Cache iTach IP2IR system, allowing to control IR controlled devices.
it is controllable from the blgw. maybe this helps.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Seanie_230
UK
Hello Beoteam
Thanks for your help.
I also had a great reply from a Excellent fellow at Bang and Olufsen called Morten the systems intergration consultant who reccomended the same thing but with one small difference which is to use the relay version
His reply was very detailed and also gave me instructions on how to set it up a snap shot is below
In order to control the curtain with a relay which I think might be the most simple to do you can use the Global Cache IP2CC.
It is a device that has 3 built-in relays either on Wired LAN (IP2CC), Wired LAN with PoE (IP2CC-P) or WiFi (WF2CC).
Seanie_230
UK
Hello All
Does anyone know the correct pins on the RJ11 for connection to a relay?
beojeff
USA
beojeff replied on Wed, Mar 16 2016 10:23 PM
I seem to recall there being a device from Lintronic that can interface with ML to send out an IR blast in a link room.
Seanie_230
UK
Hi guys
I found the solution and pins to use a global cache IP2CC and trigger the curtain track using relays
Seanie_230
UK
Hello All
If anyone is interested my Global Cache IP2CC is for sale in the for sale area as I no longer have the curtain track or a need for the device.
Sean
Page 1 of 1 (8 items) | RSS
