Spotify connect player for BS5
Not Answered This post has 0 verified answers | 106 Replies | 7 Followers
beolion
Silver Member
beolion posted on Wed, Nov 5 2014 6:19 PM
Hi
It does not looks like we are going to get Spotify Connect for BS5 ;-(
However, does anyone know that the cheapest system is that I can get to have Spotify Connect?
I then want to attach the system to the USB interface of my BS5, so I dont need a Spotify Connect speaker.
Just like PM or Airport Express with audio out, just also including Spotify Connect.
Thanks.
Millemissen
Flensborg, Denmark
You mean something like this:
https://www.gramofon.com/
http://www.techly.com.au/2014/07/06/gramofon-stream-spotify-speaker-cheap-wifi-router/
https://www.kickstarter.com/projects/fon/gramofon-modern-cloud-jukebox
Or just use the Essence-box Cool
beolion
Silver Member
Yes, that looks more like it. Thanks.
And to that price, one can still wonder why BS5 can not handle Spotify Connect.
Besides the license most likely.
gysse2004
Hellerup
Spotify Connect App for windows and Mac has been released in a Beta version, so it is definitely possible to run on a windows based machine. Big Smile
Peter
BeoMotion
I think that since yesterday the CONNECT feature is officially integrated in the normal Spotify desktop client.
Since BM5 is Windows based I had success to install that via service menu and use it in background via A.AUX.
Seams to work well as far as I can see.
So this is a solution that will actually cost you nothing and sounds much better than the USB interface with external hardware. But remember that you are doing this on your own risk!
BR,
BeoMotion.
Millemissen
Flensborg, Denmark
@BeoMotion
Does that mean that you'll have to switch to A.AUX manually?
What does the screen show - i guess just A.AUX, or?
BeoMotion
@MM
Yes, you have to switch to A.AUX manually and unfortunately you won't have any coverart since it has nothing to do with the BS5 software.
So it is similar to the "AirPlay mod" with shairport4W.
If you are using the CONNECT feature you are already holding the spotify app in your hand and won't really need the BS5 display.
Of course an Essence might be better for this purpose but if you already have a BS5 this is a good compromise. Of course the sound is also available through ML...
BR,
BeoMotion.
Millemissen
Flensborg, Denmark
What a waste of hardware and money to use a BS5 for that.
But if you already have that 'pretty thingy' hanging on the wall, I guess it is allright.
So thanks for the tip, anyway.
beolion
Silver Member
Hi
Great news, thanks. So you just need activate connect and and then a.aux and it plays?
What happens if you switch to radio? Will the connect on bm5 stop playing?
I am trying to understand how it works.
BeoMotion
I installed it on the following way:
- open service menu
- download Google Chrome since the IE seems to be too old for loading the Spotify HP
- download the Spotify windows client and log in with your account
- open the spotify preferences and activate MINIMIZED autostart, maximal playback quality and maybe disable HW acceleration (otherwise it may cause problems if shairport is also installed)
- CONNECT feature is automatically activated
-  leave the service menu
In fact it is running in background all the time and you will hear the music on all audio sources if you forgot to stop the CONNECT stream from your handheld. A.AUX is preferred since this is the only source where BS5 won't enter standby mode if no content was played during the last 10 minutes or so. (BS5 does not recognize that you play music through the "external" Spotify software...)
So it is not a very "clean and perfect" solution but seams to work if you can live with this compromise.
BR,
BeoMotion.
claudiu
copenhagen
It seems there are many of us who wish spotify connect to beosoun 5.
why not write an email to Bang Olufsen, to ask if this can not be so difficult now to introduce ??
lano
lano replied on Sun, Nov 9 2014 2:16 PM
BeoMotion:
- open service menu - download Google Chrome since the IE seems to be too old for loading the Spotify HP - download the Spotify windows client and log in with your account - open the spotify preferences and activate MINIMIZED autostart, maximal playback quality and maybe disable HW acceleration (otherwise it may cause problems if shairport is also installed) - CONNECT feature is automatically activated - leave the service menu
This worked fine for me also, nice to be able to browse music in Spotify and play it throughout the whole ML system.
With the Beolink app and MLGW I can also start A.Aux from every roomSmile
beolion
Silver Member
Hmm, could be nice if this Spotify for PC update is what B&O has been waiting for in order to enable Connect on BS5......
OK, I am dreamning, and I will try to enable this woraround soon.
Thanks for the tip Yes - thumbs up
MircoHH
Germany
Great Solution - It works!!!
Mabye B&O will implement the feature in the next OS Release :-)
beolion
Silver Member
Just installed it, and it works perfect. Thanks a lot.
Now the BS5 has my own music collection in FLAC (CD), I have the radio (RADIO), I have the built in Spotify (using it for new and top albums only) (A.MEM), and with A.AUX I have Spotify connect, AirPlay (using a Behringer USB) and DNLA streaming (using Creation5).
Starting to be a pretty well featured media player for me at least.
All I need is a BS5 app to control all the stuff. = Nice to have.
In addition, and maybe as the only one here, I use the BM5 to my TV for slideshow of all our pictures.  It streams perfect and is very fast in 1080p resolution.
Page 1 of 8 (107 items) 1 2 3 4 5 Next > ... Last » | RSS
