LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 01-31-2012 5:40 AM by the_o_master. 3 replies.
Page 1 of 1 (4 items)
  • 01-27-2012 10:05 AM
    Power supply unit / transformer for a Beomaster 5000 (Type 2005)
    Hi Beoworlders!
    I am newbie here and I must confess I have the serious B&O infection :-). It struck me like a thunder a short while ago (probably 6 Months ago). Everything started with the first Beomaster 2400. Now I own pretty nice collection of 60’s and 70’s B&O devices, some of them working, some of them waiting for a restoration.
    Back to issue, for 2 weeks I bought nonfunctioning Beolab 5000 and Beomaster 5000 (Type 2005, the old one). Inspite of the Fact that it does not work, I had to have it! At first I asked me: Is it worth the trouble to rebuild? But the answer was: Sure!
    Now, it will be repaired from friend of mine, I am not able to do these things. He made the first check with BM5000 und he detected the first Problem. The power  transformer is dead. Now we need this part and I want to ask you if anybody has it or if anybody know anyone who might have had this part?
    Is it possible to change it with other transformer from other B&O device?
    I would be grateful for any information on this issue!
    Best regards
  • 01-28-2012 11:47 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 946
    • Gold Member
    Re: Power supply unit / transformer for a Beomaster 5000 (Type 2005)
    I think the chaps to talk to hear are Frede & Martin, both members here. I would expect to pay quite a bit for a replacement transformer though!
    Olly.
  • 01-28-2012 1:07 PM In reply to
    • chartz
    • Joined on 07-20-2009
    • Burgundy
    • Posts 964
    • Gold Member
    Are you sure it is dead? It is extremely rare! I thought my Beogram CD transformer was dead, but there was a thermal switch (between the windings) which triggered (once it does, it is dead) because there was a shorted electrolytic in the power supply.
    What has your friend tested so far?
    Jacques
  • 01-31-2012 5:40 AM In reply to
    Hi!
    Thx for your tips.
    I got also a massage from Martin.
    We will try to identify if it is a power supply for 100%.
    I will inform you.
    Have a nice day
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
