Click here to tell us about your new email address
Beomaster 3300 volume will not increase, stays only low volume
Not Answered This post has 0 verified answers | 9 Replies | 2 Followers
Hen62
Hen62 posted on Sat, Nov 24 2012 6:52 PM
Hello,
My Beomaster 3300 sound volume will not go up or down, even though the controls appear to be working correctly and the volume level lights all respond when pressed individually or the up and down buttons. There is sound coming from the speakers and it sounds perfectly correct, it's just at low volume and will not increase.  Sounds like the receiver is stuck on the lowest volume setting.  The Mute button does work, and cuts off the sound.  I've looked at the manuals, but I haven't been able to find anything related to this.  Any advice would be greatly appreciated.  Thanks.  I'm in New York City.
solderon29
U.K.West Midlands
Volume is controlled by a data signal from the computer,this is interpreted by a special chip that varies the volume up and down.It's 2ic6(TDA1074)in this model,and is the most likely cause of the problem.If you are not technical though,it's best to get help from a local service centre with B&O experience.
Nick
NigelGee
I've got the same problem, did you get it sorted out and, if so, was it expensive?
NickNike
England
Would it be as simple as buying a new TDA1074 and swapping?
Dillen
Copenhagen / Denmark
Dillen replied on Sun, May 14 2017 9:57 AM
It was 4½ years ago...
NickNike
England
Does it matter? Surely people can remember back over 4 years. I bet you know the answer.
Dillen
Dillen replied on Sun, May 14 2017 3:29 PM
NickNike:
... I bet you know the answer.
And what's that supposed to mean?
NickNike
England
It means I think you probably know the answer because of your vast knowledge of the subject. That's all it means. Do you know the answer? You did ask me to come to this forum to ask the questions.
Dillen
Dillen replied on Sun, May 14 2017 4:18 PM
No, I don't know the answer.
If I did, I would have told you. Exactly as I've done countless times before.
But it's a fairly simple circuit, - why don't you diagnose it and share your experience with us here?
BTW: 4½ years - does it matter?
That's for you to decide. OP may or may not remember what was wrong, but hasn't been visiting Beoworld since 2012
NickNike
England
OK, many thanks for the info and thanks for all the help before.
There is a unit for sale on ebay. looks really good but it has the same problem with the volume remaining low. So I don't have it as yet and I was trying to get some idea of the problem by asking the experienced guys here, including yourself of course.
I wasn't aware the gentleman hasn't been on the forum for many years.
Page 1 of 1 (10 items) | RSS
