LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 08-01-2010 3:58 PM by RichC. 3 replies.
Page 1 of 1 (4 items)
  • 07-31-2010 1:10 PM
    • RichC
    • Not Ranked
    • Joined on 06-26-2010
    • Tendring, Essex
    • Posts 16
    • Gold Member
    beomaster 2200 1,6 A fuse blows as soon as switched on
    where to start? we've had a quick look , replaced fuse (which was actually 1A ) above voltage dial with a proper rated 1.6A but that blew straight away
    what's the commonest cause  for fuses blowing in these pls?
     would it be the big heavy metal thing in the middle perchance?
    Rich
  • 07-31-2010 5:00 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,004
    Re: beomaster 2200 1,6 A fuse blows as soon as switched on
    A good place to start would be to isolate the rectifier from the transformer secondary and
    see if the fuse still blows.
    If it does - the transformer or power switch is at fault.
    If not - the rectifier or something drastic around the voltage regulators and/or amplifiers has gone wrong.
    The capacitors on the regulator module PCB are causing many strange faults. A cap kit is available but
    check the rectifier/transformer etc. first.
  • 08-01-2010 10:33 AM In reply to
    • RichC
    • Not Ranked
    • Tendring, Essex
    • Posts 16
    • Gold Member
    many thanks , as always Martin.
    I disconnected everything downstream from transformer I think ...
    i.e 2 black wires disappear into voltage dial (rectifier?) and come out and feed into 1.6A fuses before entering(transformer?) via numerous waxed red & green cloth covered wires.
    More wires come out from this transformer & supply tiny PCB.... I disconnected all items from this PCB thinking that is what you had suggested .. I hope I'm right.
    Anyhow, , as soon as i hit P1 button the 1.6A fuse that feeds the green cloth covered  wire going to transformer blew.
    the other 1.6A fuse is OK
  • 08-01-2010 3:58 PM In reply to
    • RichC
    • Not Ranked
    • Tendring, Essex
    • Posts 16
    • Gold Member
    guess I'm needing a transformer ...
    I prized apart the two halves of the outer shell with the hope of having all revealed, but not a lot can be seen inside other than a white donut with a few black streaks under the plastic wrapping
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
