LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 03-16-2010 8:33 AM by Milton78. 2 replies.
Page 1 of 1 (3 items)
  • 03-16-2010 7:50 AM
    DVD 1 "double commands"
    My DVD 1 (that I use with my Avant 32 VCR) is sometimes a bit bothersome. Sometimes when I give commands (with the Beolink 1000) to e.g. skip a chapter - it skips two chapters. When I hit play, it pauses. When I want to change subtitles in the menu, it skips two languages (i.e it takes the second language, not the one I was flipping to). What could be wrong? Anyone had this problem before?
    I mean..I can live with it. But it sort of takes the joy out of watching a film when I have to beware to not skip unwantedly.
  • 03-16-2010 8:30 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,725
    Re: DVD 1 "double commands"
    Sounds like you have an audiosystem linked to your Avant? If so, try to change your option settings to V.OPT 2 and A.OPT 0 - assuming your BLs are connected to the Avant. Hope this helps
    Stefan
  • 03-16-2010 8:33 AM In reply to
    I do!
    I will try and see how it helps!
    Thanks!!
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
