LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 06-06-2010 7:03 PM by a11mcr. 6 replies.
Page 1 of 1 (7 items)
  • 03-15-2010 3:40 PM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    advise on link room speakers
    hi looking for some advise?
    i have a beocenter 9500 (which i am selling) connected to an mcl xtra speaker kit for my bathroom (built in ceiling speakers) but i have just bought a beosystem 2500 and need a bit of advise on how to connect the two 3 pin mcl plugs to the 2500?
    am i correct in thinking i need an mcl2p? and is there anything else i require?
    cheers guys
    mark
    Kind Regards, Mark
  • 03-15-2010 4:26 PM In reply to
    Re: advise on link room speakers
    That should be all - and the cables to connect it of course!
  • 03-15-2010 4:59 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks peter.
    so am i right in thinking that the amp will go downstairs near the 2500 and the 3 pin plugs just go into it and then one powerlink (fully wired 8 pin) goes from the 2500 to the amp? (i have one spare as it running a pair of pentas).
    mark
    Kind Regards, Mark
  • 03-15-2010 6:19 PM In reply to
    That is it!
  • 04-02-2010 4:39 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Hi all would i be ok using an ml/mcl converter in place of the mcl2p?
    cheers
    mark
    Kind Regards, Mark
  • 04-02-2010 5:43 PM In reply to
    Yes, it is essentially the same thing.
  • 06-06-2010 7:03 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Update, i have just bought a beolink passive for my above setup but when reading the manual it says not to use the powerlink socket, so have i wasted my money or is there a way around this??
    thanks
    mark
    Kind Regards, Mark
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
