LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 02-08-2010 7:42 PM by kai. 0 replies.
Page 1 of 1 (1 items)
  • 02-08-2010 7:42 PM
    • kai
    • Not Ranked
    • Joined on 11-16-2008
    • Posts 77
    Beovision 7-32 MK2 Hd
    Hi Guys
    Is it possible on above to connect ps3, customer already has a Macmini connected to the dvi socket, and virgin plus connected via scart. Is it possible to connect PS3, to component connections, I seem to remember trying this and it did not work. The other issue I have is with a Beovision 7-40 mk2 upgraded with HD panel Sky HD working fine but Apple TV via component, has blank screen, sound is ok, used apple remote pressing menu and plus button for six seconds then using the plus button to cycle through the different resolutions, but still blank screen, If you can shed any light would be appreciated
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
