Click here to see Christmas Prizes
Remove Beosound 9000 for the wall
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
beoaus
beoaus posted on Wed, Dec 6 2017 9:27 PM
Hello,
Could someone explain how to remove the CD unit from the wall safely?
Thanks Beoaus
Ferdinand
Malmö, Sweden
If you can stand in front of the BS9000 you have to hold it and then push upwards and then off the wall. The metal frame on the back of BS9000 is hung on a small metal plate (at the top) that is mounted to the wall.
And thanks for your post, I see now that I have to clean Big Smile
beoaus
beoaus replied on Wed, Dec 6 2017 10:25 PM
Thanks for the pictures and the reply. My cables are plastered into the wall. How do i manage those?
valve1
The south of France and occasionally Dublin Ireland
If it is mounted horizontally you can swing the bottom of it out. The weight will be held by the wall bracket. Then you can see the cable plugs. Perhaps its best if you have someone to help you.
Page 1 of 1 (4 items) | RSS
