MasterLink Gateway and Global Cache
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
huwtec
huwtec posted on Wed, Nov 8 2017 3:44 PM
Hi
I am new to this forum and fairly new to B&O and this may sound like a silly question but I can`t find any answers in past threads.
I bought a second hand MasterLink Gateway a year ago to use with my B&O equipment and the Lutron grafik eye lighting system I have installed in my house and I have managed to teach myself from different Youtube videos and information from this forum on how to program it all and it all works great. I have now bought a Global Cache IP2cc to control different items through a relay system (open/close the driveway gate, extractor fans etc.) I know there is a driver installed in the BeoLink Gateway but can it be used with the MasterLink Gateway using custom strings? If so does anybody know which IP Port I should be using? is it IP Port 4998? Also can any body tell me what the command strings should be for each of the three relay outputs on the IP2cc? I have tried various strings from the Global Cache instruction manual but I can not get it to work.
Any help with this issue would be very much appreciated.
Ralf
Hamburg Germany
Silver Member
Ralf replied on Fri, Nov 17 2017 10:54 AM
since the Ip2cc has no Restapi it is not possible to control it with custom strings, it uses sockets for communictaion a different communication concept.
There are other products from GlobalCache with restFul API.
But you can download and configure openHab, which as a modul for many GlobalCache products. openHab has a API which can to controlled by custom strings.
Another solution is the Homematic CCU2, which can control other systems with sockets and has  restful API for MLGW control.
But a lot of programming and testing is needed.
Many script languages like phython or php and others are capable of  using sockets, so you can make your own programm,e g. on a low power raspberryPi.
Ralf
huwtec
huwtec replied on Mon, Nov 20 2017 10:48 AM
Hi Ralf
Thanks for answering my question, at least now I know that the IP2CC does not work with the MLGW and was not something I was doing wrong. I think I will now go down the LinTronic relay 208 route, from what I have read on their web page it works with the MLGW and it is quite easy to program. I`m afraid you suggestion were just too complicated for me as I don’t know hardly anything about programing.
Seanie_230
UK
Hi
You could email the team at Beointergration and ask if they have a driver they could convert or one that has been converted already.
Sean
BLGW - Rekindling the love of ML
huwtec
huwtec replied on Tue, Nov 21 2017 10:34 AM
Thanks Seanie for the reply, I will e-mail Beointergration as see what they will say.
Page 1 of 1 (5 items) | RSS
