Amazing choice of pre-owned Bang and Olufsen
Got a problem with the Forum?
then please email me at keith@beoworld.org with details
Beolink 7000 problem
Not Answered This post has 0 verified answers | 2 Replies | 0 Followers
thetandyman
thetandyman posted on Thu, Oct 12 2017 12:02 AM
I have read on this site some problems with Beolink battery replacement.  I had my batteries replaced by an engineer about a year ago,  now the remote lights up,  and sits up when placed on a table,  but no contact at all.  Is there another small battery that needs to be changed as well?   Thanks so much for any info,  as I have been out of the loop for a dozen years.  Just been using a Beolink and Beo4 for the remotes.  My 2 Beolink master controls will work,  but neither one can change the volume.  I've heard this is common,  but I can't determine what is wrong.  As always,  thanks sincerely for any advice.
Weebyx
Denmark
Weebyx replied on Thu, Oct 12 2017 8:10 AM
thetandyman:
You need to change the capacitors for the IR receiver, and it would be good to change the backup battery also.
http://www.ebay.de/itm/Speicherbatterie-Backup-Battery-f-BeoLink-7000-BANG-OLUFSEN-B-O-/171190229051
Her is a thread about the recap and new backlight, it also shows the backup battery change
http://forum.beoworld.org/forums/p/3595/32375.aspx#32375
/Jacob
Langleyav
Windsor UK
Silver Member
If your batteries were changed, it has probably reverted to 2 way operation and will need to be reset to single way operating when used with a non 2 way Beomasters
Ron
Page 1 of 1 (3 items) | RSS
