LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 08-04-2009 5:04 AM by wirralsimon. 3 replies.
Page 1 of 1 (4 items)
  • 08-04-2009 4:33 AM
    • Webu
    • Not Ranked
    • Joined on 12-07-2008
    • Finland
    • Posts 21
    • Gold Member
    2-pin DIN speaker cables
    Hello Smile
    I was just wondering could anyone recommend me where to obtain good speaker cables for my Beovox M70's? I see that there's a couple merchants selling these cables on eBay, but might there be even more alternatives preferrably here in European Union?
    Unfortunately I've had a bit bad luck with AV Solutions (cracked connector covers on both shipments, not that good quality in my opinion) and Sounds Heavenly has only 5m and 10m lengths available at the moment (though they were willing to help me get them shortened!).
    Regards, Jouni
  • 08-04-2009 4:44 AM In reply to
    Re: 2-pin DIN speaker cables
    Hello Jouni!
    Let me know what cable lengths you are looking for, as you are a BeoWorld member I will do my best to help! Yes -  thumbs up
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 08-04-2009 4:54 AM In reply to
    Make them yourself and get any length you want. 2-pin DIN connectors are available in just about any electronics store (and even Biltema), and 2x0.75 mm2 lamp cord is plenty good for speaker use (heavier than B&O factory cables!).
    If you'd rather have molded connectors, I believe the cables are still available at the dealer, and the prices aren't that big.
    Although I'd just get the 5m cables and wrap the excess up, you'll want to move the equipment sooner or later anyway...
    -mika
  • 08-04-2009 5:04 AM In reply to
    I have used both iconic-av and Sounds Heavenly for cables and would highly recommend both. They are both members here.
    Simon
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
