LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 07-12-2009 4:36 PM by Steve at Sounds Heavenly. 2 replies.
Page 1 of 1 (3 items)
  • 07-10-2009 11:23 PM
    • win
    • Not Ranked
    • Joined on 03-29-2009
    • Posts 7
    Need some cable help...
    Hello all,
    I need some help.  I wanted to hook up my BL2 sub to my non-B&O tv via RCA out and needed to know what cable I need.  Will this one do?
    http://soundsheavenly.co.uk/bando-pltoamp.htm
    Thanks!!
  • 07-11-2009 1:25 AM In reply to
    Re: Need some cable help...
    Hi Win !
    I think the best is to drop a mail to Steve from Sounds Heavenly.
    He is a great guy and he will help you.
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 07-12-2009 4:36 PM In reply to
    Hi win,
    The cable you linked to allows you to connect a non-B&O active subwoofer to a B&O TV or audio system.  To connect Beolab 2 to a non-B&O system, you will need a Powerlink Trigger Box to generate the switching signals required by Beolab 2.  I can make these Trigger Boxes customised to your specification.  You may also have other issues to consider if you are connecting to a non-B&O TV, eg:-
    1) Most brands of TV have fixed line-level audio outputs, so you need to add a volume control between the TV and the subwoofer (connecting via an audio system is an ideal solution for this).
    2) If your TV or audio system only has amplified outputs for passive speakers, then you will need Attenuated Cables to reduce the signals to the correct levels for Beolab 2.
    I can help with connecting virtually any speakers to any combination of TV or audio system - please drop me a line via my link at the foot of this page with more details of the specific items you want to connect and I will do my best to help.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
