LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 07-05-2009 3:56 AM by striker27. 6 replies.
Page 1 of 1 (7 items)
  • 07-03-2009 4:46 PM
    BeoPort and Beosound 4000??
    I have a BeoSound 4000/ Overture and a Beolab 2000 hooked together via MasterLink.  I was hoping to connect this system to a new Mac Mini via BeoPort.  I would like to listen to some of my digital library.  Would such an arrangement be possible?  If so how would it be done???
    THANX
    Thanx also for your help in getting my Masterlink system up and running....
  • 07-04-2009 3:32 AM In reply to
    Re: BeoPort and Beosound 4000??
    Beosound 4000 is unfortunately not compatible with N.Music. Only beosound 3000*, 3200, 9000*, 2, 4, 5 are compatible. Have you got an iPhone or an iPod touch? * with the right firmware.
  • 07-04-2009 4:05 AM In reply to
    I never knew that!!!!   I may have to upgrade my 4000 to something a bit newer!!!!
    Yes I have an iPhone and iPod do I have any options available to me with these devices??
    THANX
  • 07-04-2009 5:19 AM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 110
    • Gold Member
    If you use Itunes you can buy an Apple airport express and will then be able to wirelessly stream the music to your BS 4000. You will also need an minijack to 5 pin din adapter to connect the airport express to the BS 40000.
    If you install the free apple remote application on the iphone you will also be able to browse your music and control it with that
  • 07-05-2009 1:17 AM In reply to
    Hi, actually you can use your BS4000 with a BeoPort , with limitations: you will have to set BeoSound 4000 to option 0 (no remote control possible), and make all connections on the BeoPort box (infra-red sensor, Powerlink sockets, among others), and set BeoPort to option 2 or 6 depending on your setup.
    My BeoPot worked with a BS2300 via datalink with the same limitations.
    Reunion Island is greeting you!
  • 07-05-2009 2:30 AM In reply to
    You are right Chris, however, the Beoport cannot be set to option 0 when connected to a Mac running Mac os X. Only option 4 and 6 and supported by BM Link.
    If striker wants to run windows on his Mac Mini then he could use your trick.
    The main limition is that you cannot start the hifi by its local controls... and that the Beoport and Mac need to be on all the time.
    I have an Airport Express and send the music to the Aux of my Beosound, I remote control it with my iPhone and I quite happy with that solution.
  • 07-05-2009 3:56 AM In reply to
    Guys these are some great ideas!!!  I never knew the B&O system could be so versatile!!!
    I will no doubt need some more help as soon as I try this!!
    lol
    THANX
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
