LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 07-03-2009 10:02 AM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 07-03-2009 5:50 AM
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Beomaster 3500 as link slave to Ouverture?
    Hi there
    I am thinking about setting up a beomaster 3500 as link slave in one room and masterlinking it to the ouverture in the other room via a converter type 1611, is this possible?
    Best regards
    Christian
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 07-03-2009 8:20 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,725
    Re: Beomaster 3500 as link slave to Ouverture?
    I had a setup that had a BM4500, sw 1.6 (1 way), a Beolink Video MKII (1615?), a TV-box (Auvisio)and a computer Monitor (Mermaid) in the link room. Main room is BS9000, BS5 and BV7-40 MKIII.
    It was possible to control mainroom video-sources by TV, DTV, DVD....Picture and sound via RF modulator. BM4500 switched to A.AUX.
    Mainroom audio-sources could be controlled by LINK-RADIO, LINK-CD..... BM4500 switched to A.AUX.
    Local audio-sources controllable by RADIO, CD, A.TAPE...
    BS4500 was not affected when the mainroom audio was controlled in the mainroom...
    I did not test sound, because no speakers were connected to the BM4500. But I think you have to change the wiring on the datalink cable, because BL Video "expects" a video source being connected, and Beovisions have different audio inputs. Option setting for BM4500 was 2.6.
    This did NOT work with 2-way audiomasters like BM7000, BC9500.
    Hope this helps.
    Stefan
  • 07-03-2009 8:55 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    Thankt Stefan, I'll give it at go. Could it work with a Beocenter 9000 or are these too old? On the other hand, I might as well try, I suppose I cannot destroy anything.
    best regards
    Christian
  • 07-03-2009 10:02 AM In reply to
    • stefan
    • Posts 1,725
    If BC9000 got an audio aux link it should work. But what I actually do not know is whether also Link audio sources will work. That was the main problem with the BM7000, BC9500. And I don`t know whether a Beolink 1611 will work. But worth a try. BTW do you want to control audio- and video-sources or just audio? I don`t think you will destroy anything. My setup is still working fine.
    Please tell us your experiences - god fornøjelse
    Stefan
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
