Click here to tell us about your new email address
BM 4400 capacitor PC1 frontend
Not Answered This post has 0 verified answers | 7 Replies | 1 Follower
kbaelden28
kbaelden28 posted on Mon, Jul 3 2017 9:16 PM
Can someone tell me which capacitor is mounted on the outside of the PC1 frontend? The service manual is not clear on this.
Kristof
Dillen
Copenhagen / Denmark
Are you asking about the 100nF polyester "tropical fish" visible in the photo?
kbaelden28
Indeed, both sides are broken while opening the metal box. So this might be the reason that I'm not getting any signal.
Is it a capacitor which is still available today ? Or is there a replacement type?
Thanks Martin!
Regards Gard's
Kristof
kbaelden28
I can't find the 100nF capacitor in the service manual either.
Dillen
Beomaster 4400 came with two different tuners.
Any 100nF polyester capacitor will work. It doesn't have to be a "tropical fish" type.
A green or orange drop would be fine.
kbaelden28
And which voltage should I take ?
Kristof
Dillen
Dillen replied on Tue, Jul 4 2017 12:40 PM
63V or higher.
kbaelden28
In other posts I read that these tropical fish are quite reliable, even if the outside cover is cracked.
I've replaced all elco's, tantals and pottrimmers on PC1, PC2 and tuner front end.
I get no signal out of the tuner, some cracks sometimes if I turn the potrimmers and move volume to 10
The signal meter also points to it's outer right most of the time. If I switch the tuner off and on then the signal meter sometimes is between 0 and 5.
 and the stereo indicator lights up.
Where should I look first ? Should I unsolder every component and check their value ? Or should I first start with the tropical fish capacitors ?
Can 'playing' with the replaced pottrimmers cause any damage to the transistors, resistors ??
Kristof
Page 1 of 1 (8 items) | RSS
