Click here to tell us about your new email address
beosound 5
Answered (Not Verified) This post has 0 verified answers | 30 Replies | 2 Followers
petelab8000
petelab8000 posted on Thu, May 18 2017 5:07 PM
Hi to you all , ok first post , I've just got a Beosound 5 all good apart from 2 things , the first one is my beo 4 will work but intermittently most of the time it's a no no . I have 2 beo4s ,one works the beocentre 2 which is all fine , and is with the  TV in the living room and is plugged into the bc 2 phono inputs and that works fine , but upstairs where the bs 5 is,Ive plugged the phono in the bs5 and select aux nothing is coming out , am I missing something here , I tried other things blue tooth also iPad but nothing , any help would be grateful it's a great system just has a few things to sort out thanks Peter
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Hi Kiran,
Glad to hear that is helpful! Cool
Yes, as long as there are no other B&O TVs on that network, you can simply patch the Converter into the ML distribution box and link the non-B&O TV to the Converter.  Any video button on your B&O remote will then trigger Converter to play sound from the non-B&O TV via ML.
If you have other B&O TVs on the same ML network, then some planning will be needed in terms of option settings, otherwise you could activate every TV each time you select a video source......
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Sounds Heavenly are proud to sponsor the BeoWorld forums!
Kiran
Leicester, England
Kiran replied on Fri, May 19 2017 2:39 PM
Steve at Sounds Heavenly:
Thank you Steve! This really has helped me a lot.
In the main house, all upstairs bedrooms currently have B&O audio systems but Samsung TVs. I plan on replacing these really slowly but what you have confirmed will help so much with current full integration 👍🏻💯🔥
Especially with my bedroom setup... I really like my Samsung 60...
Regards
Kiran
Born in NL; I ride ML
Kiran
Leicester, England
Kiran replied on Fri, May 19 2017 3:35 PM
Can someone please explain the difference between the UFO-202 and the UFO-222.
I have the UFO-202. But there is also a UFO-222 available with the same connections.
Both say ultra low latency...
Regards
Kiran
Millemissen
Flensborg, Denmark
ONLINE
The colour!
I prefer to use the Behringer UFO202, as this also has a switchable phono pre-amp fitted.
Steve.
Kiran
Leicester, England
Kiran replied on Sat, May 20 2017 9:52 AM
Millemissen:
The colour!
That red does look really nice 😂👍🏻
Regards
Kiran
petelab8000
To all the help you guys gave thanks so much . I still have a problem with my beo 4 , it will not work the bs5 ,oh it works some times but most of the time it's a no no , I've used a second beo 4 still no good any help again guys , thanks Peter
Kiran
Leicester, England
Kiran replied on Sun, May 21 2017 11:36 AM
I really don't understand what you mean by this...
Can you explain more...
Does the remote work fine with other products?...
Regards
Kiran
petelab8000
Yes Kiran , both work with my bc2 , my century and beomaster 7000, they just don't like the bs5 for some reason , they will turn it of some times or switch to cd but as quick as they work they stop , very puzzled indeed .
Kiran
Leicester, England
Kiran replied on Sun, May 21 2017 11:55 AM
There's something wrong with the BS5 then?... or the receiver?...
I can't think if anything else...
Regards
Kiran
petelab8000
Damm , OK Kiran it's not the end of the world , it's set up in the main bedroom so just have to control it from the head unit , the guy I got it from really looked arfter is as its mint even the bm5 not one mark on any of them both , thank though .
Kiran
Leicester, England
Kiran replied on Sun, May 21 2017 12:19 PM
Do you keep any other B&O product in your main bedroom?...
Regards
Kiran
petelab8000
No , just  bs5 .
Is there a plasma TV in the bedroom?  These can interfere with B&O remotes.
Steve.
petelab8000
No Sony oled   , also shut everything down even moved the bs5 still nothing , think I'll just have to use it from the head unit .
oh also been let down with the Behringer UCA 222 did someone say you sell them Steve ?
Page 2 of 3 (31 items) < Previous 1 2 3 Next > | RSS
