Click here to tell us about your new email address
beosound 5
Answered (Not Verified) This post has 0 verified answers | 30 Replies | 2 Followers
petelab8000
petelab8000 posted on Thu, May 18 2017 5:07 PM
Hi to you all , ok first post , I've just got a Beosound 5 all good apart from 2 things , the first one is my beo 4 will work but intermittently most of the time it's a no no . I have 2 beo4s ,one works the beocentre 2 which is all fine , and is with the  TV in the living room and is plugged into the bc 2 phono inputs and that works fine , but upstairs where the bs 5 is,Ive plugged the phono in the bs5 and select aux nothing is coming out , am I missing something here , I tried other things blue tooth also iPad but nothing , any help would be grateful it's a great system just has a few things to sort out thanks Peter
beojeff
USA
The BeoSound 5 must be set to audio master in the settings in order to access the aux input of the BeoSound 5. You can only have one audio master in a master link system. Maybe you have both the BeoSound 5 and the BeoCenter 2 connected to the ML and have the BeoCenter 2 set as audio master instead of the BeoSound 5?
petelab8000
Many thanks thanks for the info , bs5 is set to audio master also both systems are stand alone not in a ml set up . Thank you .
petelab8000
Thanks for the info , bs5 is set to audio master also it's not in a ml set to bc2 regards Peter .
Millemissen
Flensborg, Denmark
Sorry what doyou mean by 'plugged the phono in the bs5'?
What have you plugged in and where???
petelab8000
Ok on the back of the back of the beomaster box is 3 phono sockets 1vidio & 2 audio , like bc2, so I've plugged into them then select aux . But nothing coming out , everything els is perfect , sorry not the video just audio .
Opman
Opman replied on Fri, May 19 2017 8:59 AM
The phono sockets on the back of the BeoMaster 5 are not audio inputs. You need to purchase an adaptor to use the USB input. You can purchase this device made by Behringer U-CONTROL UCA 222.
Regards
Opman
Kiran
Leicester, England
Answered (Not Verified) Kiran replied on Fri, May 19 2017 9:39 AM
This is what you need...
Works totally fine for me - A.AUX
Buy the 3.5mm to RCA from Steve @ Sounds Heavenly 👍🏻👍🏻
I have been trying to find mine but its somewhere lost in the house lol...
Regards
Kiran
Born in NL; I ride ML
Millemissen
Flensborg, Denmark
Installed one yesterday (along with a Playmaker).
That definitely works - and it is also the official recommendation from B&O.
Millemissen
Flensborg, Denmark
petelab8000:
Please note, that if you intend to connect the audio of a tv this way, you will probably run into sync problems due to rhe processing of the sound in the connection chain.
StUrrock
StUrrock replied on Fri, May 19 2017 11:42 AM
Millemissen:
Horrible sound quality Devil not B&O at all
petelab8000
Guys thank you so much , you know yr stuff , have ordered a Behringer uca222 it's coming Monday , just one more thing , if they work on my bc2 , what are they for on the beomaster 5 then ?? Thanks again for all yr help ..
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Millemissen:
petelab8000:
Hi MM,
Yes, you are quite correct, the Beomaster 5 processing causes a delay to sound that comes in through the USB input, which will cause lip-sync issues if you try to connect a non-B&O TV this way.
The only solution to this is to buy a Beolink Converter from Bang & Olufsen (type 1161166) and connect this to the Beomaster 5 with a Masterlink cable: http://soundsheavenly.com/48-masterlink-control-and-sync
You can  connect the headphone output of the TV into the B&O converter with this cable:-
http://soundsheavenly.com/bang-olufsen/67--trs-5pd-.html
You can then listen to the TV through the Beomaster 5 without an audio delay by pressing “TV” on your B&O remote control.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Sounds Heavenly are proud to sponsor the BeoWorld forums!
petelab8000
Sorry forgot also my beo4 remote will not work it have tried both so know it's not them , any ideas . Thanks
Kiran
Leicester, England
Kiran replied on Fri, May 19 2017 2:23 PM
Steve at Sounds Heavenly:
Steve you have just solved my ultimate problem for non B&O TVs! Thank you!!!
But now that the 1161166 converter uses the Masterlink slot from the audio system, how can I incorporate this converter into a whole masterlink for that 1 specific non B&O TV? Can I just patch the 1161166 converter into the RJ45 Masterlink patch like below?
Regards
Kiran
Page 1 of 3 (31 items) 1 2 3 Next > | RSS
