Click here to tell us about your new email address
New Beolink2 App and Master Link Gateway (MLGW)
Answered (Verified) This post has 2 verified answers | 5 Replies | 2 Followers
Reto
Zurich
Reto posted on Thu, May 18 2017 4:42 PM
Dear forum members
Is somebody using the new Beolink2 App while connecting to a MLGW? According to the App Description it should be supported. But I'm wondering if this is really true as I can't connect to the MLGW.
Thanks a lot for any comments.
Reto
Griebel
Verified by Reto
The current version of the BeoLink 2 does not work properly with MLGW. A new release is scheduled next week that should solve the issue.
Griebel
Verified by Reto
New version has been released. The MLGW compatibility issue has been solved.
Griebel
Verified by Reto
Reto
Zurich
Reto replied on Fri, May 19 2017 4:09 PM
Ah cool, thanks.
Griebel
Verified by Reto
Reto
Zurich
Reto replied on Mon, May 22 2017 7:31 PM
Ok, I see the BLC sources (Deezer and TunIn in my case) now and can select them, but no reaction while trying to switch the essence and the TV on by the App.  Same behavior while switching the system on using the old Beolink Gateway App and trying to change Volume or switching the songs using the new App.
Reto
Zurich
Reto replied on Tue, May 23 2017 8:01 AM
Hm, it's working now. I guess the problem is caused by a constantly losing connection to the MLGW. After re-login it's working fine until I get the revolving Message that there could a new Gateway be found.  Hence I have to re-login again.
Another problem I encountered is while selecting Deezer from the BLC or an A6, I neither see the Deezer playlists nor the track currently playing.
Regards
Reto
Page 1 of 1 (6 items) | RSS
