Click here to tell us about your new email address
Wanted: Parts for Beogram 4002 type 5501
cozza
Posts 20
Silver Member
cozza Posted: Tue, May 9 2017 4:28 AM
Hi all.
I am repairing a beogram 4002 on behalf of a friend. The clear plastic optical "ruler" with the sense lines is broken and is missing the end piece. Also one of the mechanical leaf switches underneath (the inner limit stop switch) is broken.
I would like to buy these bits, if anyone has parts machine with them still in place please.
Thanks!
Colin.
Dillen
Copenhagen / Denmark
Posts 9,313
Dillen replied on Tue, May 9 2017 7:09 AM
Both parts exist in more than one version.
The ruler with different markings.
A couple of photos would be helpful.
cozza
Posts 20
Silver Member
cozza replied on Wed, May 10 2017 2:03 AM
Yes, of course. Here are pictures of the two items. The photocoupler lamp arrangement is how it arrived on my workbench, and will be changed back to original.
I discovered the spring for the microswitch in the bottom of the unit, but the actuator lever has a kink in it and the spring does not stay in position correctly, despite straightening.
cozza
Posts 20
Silver Member
cozza replied on Wed, May 10 2017 2:07 AM
Also, I noticed the cover for the lamp is missing, so I will have to source this part or fabricate something to suit.  I suspect a high wattage lamp was fitted and caused the damage to the optical interrupter and lamp housing.
Page 1 of 1 (4 items) | RSS
