Click here to tell us about your new email address
Hello! can do it with this type of cd player?
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
Nic93
Is located in south denmark aabenraa/rødekro
Nic93 posted on Sun, May 7 2017 7:36 PM
is it possibel with a beogram cd 3300 to work on a beovision mx 8000 tv?
Peter
Earsdon
Peter replied on Sun, May 7 2017 8:49 PM
Yes, but not as you would want it. You can no doubt get a cable so the audio can go through the TV via either a SCART or possibly S-VHS plugs. The CD would not be remote control. The better way to do it would be to connect it to a MCL equipped Beomaster, get a MCL/ML converter and then you will have full AV integration. The problem you no doubt have is that the Beomaster 3300, although using the Beolink 1000 codes, doesn't work properly with MCL . I would get something like a Beosystem 2300 and simply use ML - the 2300 should be very cheap these days.
Peter
Nic93
Nic93 replied on Sun, May 7 2017 8:53 PM
So i cant hook it thou the input port on the back of the beovision and get sound that is?
since its haveing input for cd playback, right? i was given that specific model thou as a present today.
Page 1 of 1 (3 items) | RSS
