Click here to tell us about your new email address
beomaster 2000 indicator lights
Answered (Verified) This post has 2 verified answers | 19 Replies | 2 Followers
johndon
Silver Member
johndon posted on Sat, Apr 22 2017 2:01 AM
Hi
I am new to this forum.I live in Brisbane Australia. I purchased my B&O system in 1975. It comprises a Beomaster 2000 ( 2801), Beogram 4002 and a pair of M70 speakers. I did have a Beocord 2000 but it died a long time ago. The amplifier was working OK but the heatsinks were getting really hot. Thanks to this site, I found how to cure the overheating. I still have one problem. None of the indicator lights work. The individual bulbs are all ok. I have desoldered them, checked continuity across the terminals of each bulb and resoldered them back on to the board  (4)
The unit is on the workbench and I have tested the input voltage into board 4 and it's OK but the bulbs still don't light up. Can anyone give me some ideas of where the problem might be. I am NOT an electronics technician however my late father was so I have picked up a bit of knowledge from him. I have downloaded the service manual and I can sort of follow a circuit diagram and use a multimeter.
johndon
Silver Member
Answered (Verified) johndon replied on Sat, Apr 22 2017 10:08 PM
Verified by johndon
Hi Martin
 Thanks for the info. I'll let you know the result.
I do have another small problem. I changed the 2 trimpots on board 7 to fix the overheating problem. When I installed the new ones, I wound the trimpots to zero and then brought them up slowly until I got the correct value reading on R117 and R217 as per the service manual. However the next time I checked, the left channel ( R117) reads exactly 10mv but the right one ( R217) fluctuates wildly up and down. The cooling fins stay cold.   Any ideas?
regards
John
Menahem Yachad
Jerusalem, Israel
Verified by johndon
You changed the Zener Diode?
Do you mean the Tuning Voltage 22V Zener?
If so, you cannot use a standard zener.
You must use a Temperature Compensated Zener, otherwise the stations will fluctuate all over the dial, and you'll have the problem of no stereo.
Anyway, if you still have the original zener, then reinstall it, or look for a ZTK22, originally made by Telefunken or Siemens, now Vishay.
Menahem
Menahem Yachad
Jerusalem, Israel
Big mistake of newbies is to replace semiconductors willy-nilly, without ever having checked them.
I suggest that you replace NO transistors here, until you have confirmed with ABSOLUTE certainty that they are defective.
If you replace a transistor with the same model, but a different hFe gain grade, you can induce oscillation, and cause catastrophic failure where none would have occurred before.
Enthusiasm is fine, but uneducated enthusiasm is deadly.
You really need to know what you're doing, before changing transistors.
I do not see where in any BeoMaster 2000, that you need 4 MPSA06's.
There are only 2 of these NPN's installed in the machine.
The other 2 MPS's are PNP's, and if you replace NPN's into the place of a PNP, you can sell tickets for a nice light and sound show.
So, I'd advise you just to hold off laying out money right now, except for a Transistor and hFe checker.
Dillen
Copenhagen / Denmark
Great idea to make sure, you know what you are talking about.
Beomaster 2000 was made in two different versions (Both are Type 2801).
The amplifier module was revised from serial number 143001.
johndon
Silver Member
Hi Martin & Menahem
The serial number of mine is much higher. When I test the transistors, is it OK to leave them soldered onto the board or will the meter pick up from something else in the circuit?
 I now have hook leads for my multimeter.
John
Dillen
The meter just sends out and receives.
It cannot see what it is measuring into or onto - and neither can you if you leave other components connected to the device undergoing tests.
Menahem Yachad
Jerusalem, Israel
As a general rule, all components must be removed completely from the PCB, in order to test them.
The rare exception (and even that is not always correct), is testing a capacitor for ESR.
You need a special ESR Tester for that.
If you want quality equipment for hobbyist purposes, check out Peak Electronics.
Their Capacitor tester is the ESR70
Their SemiConductor Tester is the DCA75
Page 2 of 2 (20 items) < Previous 1 2 | RSS
