Click here to tell us about your new email address
BV14 and BeoRemote One BT lists
Not Answered This post has 0 verified answers | 23 Replies | 2 Followers
Chris Hassell
London
Chris Hassell posted on Fri, Apr 21 2017 6:31 PM
Hi there, i have my BV14 installed. Woohooo. Multi room seems to be behaving etc. However I cannot for the life of me find out how to edit what appears in 'List' on the BeoRemote One BT for each source. Anyone got any idea?
Whilst we're on it - I don't seem to be able to set a stand position for each source as I could do on my BV11 - is this just not there yet?
BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Kiran
Leicester, England
ONLINE
Kiran replied on Fri, Apr 21 2017 6:47 PM
You need to do it from the remote advanced options 👍🏻💯
Regards
Kiran
Born in NL; I ride ML
Kiran
Leicester, England
ONLINE
Kiran replied on Fri, Apr 21 2017 6:53 PM
You need to add the sources to LIST from the remote's advanced options 👍🏻💯
Regards
Kiran
Kiran
Leicester, England
ONLINE
Kiran replied on Fri, Apr 21 2017 6:54 PM
You need to add the sources to LIST from the remotes advanced option.
They maybe under the MUSIC button?
Regards
Kiran
Kiran
Leicester, England
ONLINE
Kiran replied on Fri, Apr 21 2017 6:56 PM
You can add and remove sources under MUSIC and LIST from the remote's advanced options under LIST.
Regards
Kiran
Kiran
Leicester, England
ONLINE
Kiran replied on Fri, Apr 21 2017 8:27 PM
lol
Regards
Kiran
Chris Hassell
London
Kiran:
Regards
Kiran
Thanks for the response @Kiran but that only seems to work for when the remote is in IR mode. What is available in LIST seems to be sent to the remote from the BV14 when in Bluetooth mode. Confused
Chris Hassell
London
Kiran:
Regards
Kiran
Thank you @kiran but I think that's only for IR mode. The contents of LIST seem to be sent from the TV over bluetooth. I can't see any options to edit this on the TV though.
Kiran
Leicester, England
ONLINE
Kiran replied on Sat, Apr 22 2017 8:39 AM
Wow I don't have experience with the Bluetooth side of BeoRemote One. Mine is IR. Is bluetooth built into the new remotes?
Hopefully someone will be able to help you 👍🏻
Regards
Kiran
Millemissen
Flensborg, Denmark
You can (re)name the sources as you please, when setting these up.
And you can decide if or not and where they should appear in the lists on the remote.
See page 24 - 'BeoRemote lists' in the userguide.
Chris Hassell
London
Millemissen:
Thanks @millemissen for your help - I found this, but what I'm wanting to do is manage what is available when I press 'list' on the various sources I have. There's lots of default stuff in there I don't want displayed for example.
I'm guessing they will add this in an update if it's not there now as it means you can't edit what's shown for 'light' and 'control' when in Bluetooth mode. This is a whole other subject though about the BV14 and the BLGW which I'm going to be posting about in home automation!
digi
Bremen
digi replied on Sat, Apr 22 2017 11:43 AM
Hi Chris,
do you see the option "Text" (Videotext) in your TV-"List"?
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000, AAX 2; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8+H3
Sandyb
Sandyb replied on Sat, Apr 22 2017 12:47 PM
Chris....you have to do it on the tv settings....chose a source from the source list, select menu lists, and go from there.....it is different from the regular BR One...
what you can't do yet (i believe) is (a) edit the Music and TV list that appears on the home screen of the BV14......and (b) when you link a product to the BV14, all of those sources appear on the remote and home screen Music / TV icons......
guessing those latter two cases need to be added as options....
Chris Hassell
London
Thanks @sandyb I'll try tonight. Have had the parents down this weekend. I'm sure I didn't see this in the menus before but will report back.
You're correct on the other issues too. Annoying that I can't hide/deactivate the sources coming from my Essence over the network on the TV. It's even more frustrating that I can't set stand positions for sources and also set settings on the shared sources as you can on the local ones. Grrrr!
Still love it though :-)
Chris Hassell
London
Hi @sandyb have a look at the attached picture - there is the "BeoRemote Lists" menu but this just defines where the source is shown on the remote menus. I can't see anywhere to change what's show in 'List' for each source on the remote Sad
Page 1 of 2 (24 items) 1 2 Next > | RSS
