LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 03-15-2009 3:29 PM by Steve at Sounds Heavenly. 4 replies.
Page 1 of 1 (5 items)
  • 03-14-2009 1:08 AM
    need cable to connect Beosound 1 and ipod touch
    I need to find a cable that would connect my Beosound 1 to my i pod touch. Is that cable available in the US?
  • 03-14-2009 7:53 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 637
    Re: need cable to connect Beosound 1 and ipod touch
    It sure is.  Check the Store Locater at B&O's website for your closest dealer.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 03-14-2009 10:21 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,036
    If not then simply contact one of the sites sponsors - Steve at Sounds Heavenly - his cables are superb and sre used by many dealers of used B&O including our very own site owner Lee at LifeStyle AV. Steve's cables have an excellent reputation and are highly recommended by other Beoworld members.
    Chris.
  • 03-14-2009 5:52 PM In reply to
    I found the cables at an B&O store in the chicago area. The i pod sounds great on the beosound 1. Thanks for the help.
  • 03-15-2009 3:29 PM In reply to
    Glad you've found a cable, jackdaniels413.
    By the way, thanks for the mention Chris! Yes -  thumbs up
    For any other Beosound 1 owners wanting to connect an iPod/MP3 player to the Aux socket, it is worth noting that you need to press the two arrow keys either side of the <CD> button simultaneously to activate the Aux input.
    And yes, I can help if you need a cable! Laughing
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
