"BeoSound Baron" Home-Made
This post has 15 Replies | 0 Followers
baronvejrup
Posts 25
baronvejrup Posted: Fri, Mar 24 2017 4:51 PM
I have for a long time considered the Beosound Moment, but if it should fit my BV14 Smoked Oak and A9 Smoked oak, I had to do something with the wood on the moment... I've tried the moment a few times but I can't seem to figure it out, I think my iPad is a much better tool, for the whole link system in my home... But I do love the look of the moment..
So what to do..
I made my own iPad dock... Here is some pictures of the final product and some of the building process.
It took around 15 hours to do and around 3 days for the oil on the oak to dry.
This was the Oak Block it all came from
Dillen
Copenhagen / Denmark
Posts 9,827
Dillen replied on Fri, Mar 24 2017 5:03 PM
Thread moved.
Please keep the General forum section on B&O related topics.
Nice work BTW.
Jeff
USA
Posts 2,789
Jeff replied on Fri, Mar 24 2017 5:12 PM
Very nice, good work! I like it, and it's probably going to be less hassle and more reliable than the Moment sadly.
Jeff
Beovirus victim, it's gotten to be too much to list!
baronvejrup
Posts 25
Dillen:
Thread moved.
Nice work BTW.
Sorry thought it was a general discussion, but thanks for the move ;-)
baronvejrup
Posts 25
Jeff:
Thanks Jeff.... I dont have any experience with the stability of the moment, but I didnt like the general usage of the product... and my ipad can control my home with the BeoMusic app, now I just need the new Bang & Olufsen app for iPad and the BeoRemote to work with BV14, then it will be a great succes
Millemissen
Flensborg, Denmark
Posts 10,013
Looks really nice - you are a skilled DIY'er Yes - thumbs up
A few questions, though.
Can the iPad also be placed in there with the screen turned towards you?
If yes, how do you primary use it? Sitting in the dock or just placed with you on the 'coffe table'.
Isn't it rather heavy stuck in that piece of oak?.
baronvejrup
Posts 25
Millemissen:
Hi MM
Yes the iPad Can connect both ways, I usely take the iPad with me and browse songs and when I'm done I'll put it back.
it will only charge if its put in the dock with the oak as front!
its not really heavy it actually feels like a premium product, like beo4 compared to BeoRemote because of the weight.
Millemissen
Flensborg, Denmark
Posts 10,013
A sophisticated docking station, then ;-)
baronvejrup
Posts 25
Millemissen:
Yep nothing else.
it works great with BeoMusic and hopefully the new bang & Olufsen app will come to iPad soon
TWG
Posts 1,179
TWG replied on Sun, Mar 26 2017 9:00 AM
Very nice and well made!
egges
germoney
Posts 281
egges replied on Sun, Mar 26 2017 2:06 PM
baronvejrup:
.... hopefully the new bang & Olufsen app will come to iPad soon
once on an iPhone you can download it on an iPad.
and, of course, a nice work you did 👍
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + amazonFireTV, appleTV (4th. gen.) und Samsung BluRay-Player; BeoSound 2 (drahtlos), BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (macmini, macbook, ipads, iphones) und als Frühstücksradio gewissermaßen: A6 oxidised brass SE
baronvejrup
Posts 25
TWG:
Thanks TWG Smile
baronvejrup
Posts 25
egges:
baronvejrup:
Haven't seen it in the iPad store... it only shows up when I search for the app on the iPhone...
And thanks
baronvejrup
Posts 25
baronvejrup:
egges:
baronvejrup:
And thanks
Hi Egges
Found the app on the iPad, it was a setting, I only searched for iPad apps...
But wow it looks bad, hopefully they will make a specific app for the iPad layout.
Andrew
Frinton, UK
Posts 697
Silver Member
Andrew replied on Fri, May 12 2017 11:46 AM
Wow that looks great - wish I had those skills as I am looking for something just ike that to hold my ipad.
I also made my own sort of moment when my BM6000 stopped working and I looked for another solution -  I did the following:
Bought a one remote aux expander - this works on B&O commands and gives you three inputs http://shop.oneremote.dk/catalog/index.php?cPath=3_4 - I use one input for a the one remote internet radio - teh second is for a playmaker and third for my revox B77. The aux expander is programmed for Radio (internet Radio) CD (Playmaker) and A.Tape (Revox) into the Playmaker is plugged a BG 6002 via a Rega Phono stage. So all of this works with a Beo4.
I then connected a Lintronic box to a Beolink Converter and made a lead to feed it directly with link signals - that enabled me to control the whole setup from any link room. I programmed the box to repeat B&O Commands and run a macro that when Phono is selected, calls up the playmaker and switches it to aux in.Because the lintronic repeats the B&O commands it means you can also skip backwards and forwards, or pause within playlists or albums via playmaker which, I set to line level out.
In my music room I installed a Beolink Active which is connected to a Linn LK140 and two M100-2 - the result being that all the messy equipment is intalled in a cabinet and I can simply press radio and the radio station to get internet radio, CD to play playmaker, A.Tape for the revox and Phono for the Beogram. For recording onto the Revox the audio out from the PC input on the BLA is used - It all sounds fantastic and the linn power amp drives the M100-2 beautifully. I can use the system fully from any room and programme it to wake me up in the morning..
I'll try and post a picture but basically managed to get everything I wanted quite simply and without spending a fortune. The ipad is particularly good for music as easy to update, and if it goes wrong just get another, of course it can also be used with iPhone and Android for guests.
Here is a list of equipment - note that most of it has been bought over a period of time so hasn't been bought in one go - had I bought it in one go it most likely would have been cheaper to just buy a Moment!
Existing Equipment
One Remote Internet Radio
Lintronic Box
Playmaker
Beolink Converter
Beolink Active
Audio bits - Revox, BG6002, M100's
Additional Equipment
One Remote Audio Expander, plus leads to connect everything up.
Linn LK140 to drive the speakers instead of BM6000
Andrew
Frinton, UK
Posts 697
Silver Member
Andrew replied on Fri, May 12 2017 12:14 PM
Still some work to do tidying it all up
Page 1 of 1 (16 items) | RSS
