Click here to tell us about your new email address
Beomaster 2400-2 Repair
Not Answered This post has 0 verified answers | 8 Replies | 0 Followers
Anil
New Delhi
Anil Huh? [:^)] posted on Sat, Mar 18 2017 11:10 PM
I have a Beomaster 2400-2 which is non operational for several years. Only a red LED lights up , None of the touch controls work.
I would like repair it , but have no idea where to start. I don't have the technical Manual as well.
Is it possible to bring it back to life
Anil
Dillen
Copenhagen / Denmark
ONLINE
Dillen replied on Mon, Mar 20 2017 6:39 AM
mehtaanil:
Yes.
Anil
New Delhi
Anil replied on Thu, Mar 30 2017 2:43 AM
Martin,
Hello, Thanks for assuring me. Please tell me how I should start to bring the Radio back to life
Thanks a lot for your help
Dillen
ONLINE
Dillen replied on Thu, Mar 30 2017 6:42 AM
We don't know how skilled you are in these matters or which tools and instruments you have at your disposal, but
basically you will have to take a couple of covers off, check things and measure around a bit.
If none of the touch fields are working, you could start by checking if the Beomaster was put together correctly.
If not, there's a good chance the sensor pads little bronze forks aren't gripping their respective pins on the underlying
circuitboard.
All fine but still no go? Check the low voltage power supply for amount of ripple and put an oscilloscope to the
signal from the sensor pad circuits oscillator to see if things are as expected.
In short; Put the patient on the bench with your tools and instruments, study the schematics, - diagnose and repair.
As you work your way around the Beomaster and get things to work, you will most likely find that a more thorough replacement of
capacitors will be in order. some will probably be bad and most will be marginal by now with a loss of capacitance and increased ESR.
Alignment trimmers will also be in need of replacement and realignment.
The idle current settings in particular - so keep an eye on them if you get the Beomaster to power up, a multimeter (or perhaps two) across the
emitter resistors would be fine if your variac doesn't have mains current monitoring.
But get it working first - or at least sort of.
Craig
Yarm, United Kingdom
Silver Member
Craig replied on Thu, Mar 30 2017 7:40 AM
Take some pictures too......worth a thousand words
Anil
New Delhi
Anil replied on Thu, Mar 30 2017 6:46 PM
Martin,
Your ideas are a ray of hope, While I did my soldering & instruments practice in engineering school about 35 years ago. I still feel I could find my way around.
I have a multimeter with me , however no scope, will it be a serious handicap?. You have mentioned changing the capacitors,How do I identify the capacitors rating , is there some readily available list which I can check off.
With the Low Voltage Power Supply, is there any particular voltage to look out? at some TP
And yes I will keep coming back to you if I get stuck somewhere, hope you don't mind.
Anil
New Delhi
yes Sir
Dillen
ONLINE
Dillen replied on Thu, Mar 30 2017 6:54 PM
mehtaanil:
The servicemanual springs to mind as the answer to both.
And most caps have their basic specs stamped on them.
Capacitor kits are readily available - but a completely dead Beomaster will most likely not be down to bad capacitors, so I suggest you
do some diagnosing before upgrading/recap'ing.
There's always a risk of introducing new faults that would be difficult to find with the original fault(s) still around.
Anil
New Delhi
Anil replied on Thu, Mar 30 2017 7:10 PM
Could I get the manual , so U can refer to it
Page 1 of 1 (9 items) | RSS
