Click here to tell us about your new email address
Beomaster 3000 compatibility question
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
AnthonyJan
AnthonyJan posted on Tue, Mar 7 2017 12:56 AM
Father-in-Law has a Beomaster 3000, ot is barely used and I want to hook the thing up.  We are looking for a CD player to match the receiver.  I have found a Bang & Olufsen Beosystem Beogram 4500 CD Player.. would this work with my existing system if I hook everything up?
Orava
Finland
Orava replied on Wed, Mar 8 2017 7:51 AM
BG 4500 has 7-pin DIN connector, outermost pins are screw type and must be removed because your 3000 has 5-pin. Otherwise should be ok in tape/aux connetor.
Beware with pins DO NOT loose them. They are needed for remote operation.
AnthonyJan
So, I just simply remove the extra pins?  If I remove the pins, I will not be able to use the remote?  Is there away to have remote operation with the 5-pin setup?  Sorry if these are dumb questions.
Orava
Finland
Orava replied on Mon, Mar 13 2017 8:46 AM
No, there is no remote reciever in bg 4500. It is controlled via those pins by Beomaster witch have remote reciever(data link), like beomaster 4500, 5000, 6500... BM 3000 does not have that.
Page 1 of 1 (4 items) | RSS
