Click here to tell us about your new email address
Beovox S45.2
Not Answered This post has 0 verified answers | 35 Replies | 0 Followers
Craig
Yarm, United Kingdom
Silver Member
Craig posted on Wed, Mar 1 2017 3:43 PM
I have recently acquired a pair of S45.2 speakers from retro junkie of ebay fame, one of which was described as having a woofer driver seized, not taken them apart as yet due to the volume of mundane tasks dictated by the woman in my life, however I suspect a misaligned magnet as this seems to be the most prevalent thread posted in these rooms. When I get permission to revert to my own activities once more I will chronicle the excercise along with some pictures.
Craig
Silver Member
Finally got round to having a look, first one has a couple of heavy scratches on one side, the cloth looks worse for ware in one corner.
Craig
Silver Member
This will require both speakers being recovered....
Craig
Silver Member
the bass driver is frozen solid, the rubber mounts look in good shape however
Craig
Silver Member
finally getting back to the proper jobs in my life, removed the driver from the cabinet
Craig
Silver Member
however I'm at a bit of a loss as to the best way to get into it
Craig
Silver Member
I think the grill type cover needs to be removed, the cobalt magnet looks like it could easily be damaged however
Craig
Silver Member
So.....any advice from those who have been here before would be welcome
beo3000
beo3000 replied on Tue, Mar 28 2017 11:53 PM
Great speaker's I am yet to hear better waiting on some s75's
good luck with your project
Craig
Silver Member
Craig replied on Wed, Mar 29 2017 7:44 AM
found this http://forum.beoworld.org/forums/thread/191211.aspx
Irata has documented the procedure very well in this blow by blow thread......
priklep
Slovakia
Dear Craig,
S45-2 speakers are very good playing speakers and definitely worth to restore them.
Wood work could be done with great success, you will find here veneer repair here in forum. Take some drops of hot water to the wood scratch (only) or use steam from boiling water, hot water will help to recover wood.  After some hours clean veneer with isopropyl alcohol and take sand paper ...
I was trying to repair dislocated magnet using above mentioned thread and no luck, I was not able to center the coil inside magnet.
So another solution for me was to ask Dillen (Beoworld respected member), he helped me to source woofer easily.
Craig
Silver Member
Priklep
Thank you for your encouragement, I will certainly give these speakers my best shot. Gripped the errant driver in a vice this evening and was shocked by how easily the magnet detached from the housing, it was almost like the only thing holding it in place was the paint.
Craig
Silver Member
The pole piece is still securely fixed and looks central in the magnet, as I see no reason to disturb it I'm going to clean it up in situ.
Craig
Silver Member
The dremel with a wire wheel lends itself to this task quite well
Craig
Silver Member
the magnet and pole piece now look acceptable, and feel very solid.
Page 1 of 3 (36 items) 1 2 3 Next > | RSS
