Click here to tell us about your new email address
BM5 HDD to SSD the easy way
This post has 8 Replies | 3 Followers
Wild Ruedi
Zürich Switzerland
Posts 21
Wild Ruedi Posted: Sun, Feb 5 2017 10:39 PM
Hello
My BS5 suffered from staggering replay from the memory.
I have followed the various attempts to change the HDD to SSD. I bought SSD crucial MX 300 1 TB.- 1050GB to be precise. Also: sharkoon  Quickport XT duo clone.
Workaround: Connect the cloner to PC and plug new SSD in any slot. Formate SSD Fat32. Unplug cloner from PC. Plug original HDD in clonerslot1 new SSD slot2. Start cloner and wait, watch the LED for progress. It takes about 3 hrs.
Put back SSD in BS5, plug everthing together, plug in mains, wait until System is ready and enjoy the quick response at the wheel and the fast browsing through albums. The memory plays smooth.
No more worries about mechanical failure!
Best regards
Ruedi
Weebyx
Denmark
Posts 702
Weebyx replied on Mon, Feb 6 2017 6:51 AM
Wild Ruedi:
Hello
Best regards
Ruedi
Was your original HDD 500gb or 1TB ?
And still no problem with SW updates ?
/Weebyx
beolion
Posts 264
beolion replied on Mon, Feb 6 2017 1:00 PM
Thanks for the tip. That is a quite nice and straight forward approach.
I hope that the MX300 will work flawlessly for you, someone mentioned that only the MX100 would be supported by the BM5.
Please let us know how it goes, I am also having a 1TB and the response is sometimes slow on mine as well.
Wild Ruedi
Zürich Switzerland
Posts 21
It was 1TB and I have Spotify - all works perfect. I have not tried the update function since it says, that my cloned software is updated.
Wild Ruedi
Zürich Switzerland
Posts 21
Wild Ruedi
Zürich Switzerland
Posts 21
Wild Ruedi:
I have tried the update - and it works! First I made a reboot from recovery witch sets the sofware to delivery status: update lost, settings lost, music files
remain untouched. It takes a while. Then settings - update and the download starts as ever. In short time the update is done and Spotify + A Aux
is back. So far I did not use the service mode nor the USB service tool. The easy way.
regards Ruedi
beolion
Posts 264
beolion replied on Sat, Feb 11 2017 9:32 PM
Thanks for your update.
wantoniak
Posts 21
Hi
How is your replacement drive?
Hope all works well. Can you please confirm that your drive  model number is Crucial SSD MX300 1050GB 2,5" (CT1050MX300SSD1)
Wild Ruedi
Zürich Switzerland
Posts 21
Correct!
and it works perfect!
regards Ruedi
Page 1 of 1 (9 items) | RSS
