Click here to tell us about your new email address
Battery power
benjnz
Posts 51
benjnz Posted: Mon, Jan 30 2017 7:33 PM
All of a sudden (after 1 month of use) my BT version of the remote is totally draining batteries within one day and refuses to power up the next day. Have tried both traditional and re-chargable batteries and getting the same result.
Is there something I should be doing with the remote to stop the power drain?Sad
Set-up is BV4-42 and Apple TV (latest version). The remote is pared to the ATV and I can switch between BEO4AV mode and ATV BT mode, so just use the one remote.
Thoughts?
Keith Saunders
Little Ann, Hampshire, United Kingdom
Posts 4,826
benjnz:
Do not use re-chargeable batteries, most are 1.2 volts rather then 1.5 volts.
Use good quality AAA batteries should be used and fitted as below
Regards Keith....
benjnz
Posts 51
benjnz replied on Wed, Feb 1 2017 1:53 AM
Thanks, I have tried normal expensive energiser batteries and they also discharge, will try again tonight to make sure am not totally loosing the plot Big Smile
Page 1 of 1 (3 items) | RSS
