Click here to tell us about your new email address
Beomaster 4400 - recycling bin or repair ??
Answered (Verified) This post has 3 verified answers | 19 Replies | 2 Followers
ALF
AUS
Silver Member
ALF posted on Fri, Jan 20 2017 10:03 AM
greetings all,
I have been working on a resurrection project with my BM4400 DOA!!
what happened in the meantime:
replaced all electrolytic caps plus some dead bulbs - nB.: the FM signal-strength is not illuminated no does it show any sign of life - both red tuning indicators however work
replaced the big 10000uF caps
replaced both out-put trimmers R177/277
replaced both pairs of the wirewound resistors R178/179 and 278/279
replaced all TO-92 transistors in the power-amp section except 0TR 100/200
replaced all TIP-141/146 pairs.......faked parts ???????
some work as you can imagine.....
to the test:
one big bang and the TIP146s literally exploded !!!! quite frightening !!
meaning: there is something else terribly wrong ????????????
+35V and -35V is there as well as 15V.
can somebody shed some light on this and give me some pointers ?
after all this work it would seem such a waste to just recycle the unit
cheers ALF
Craig
Yarm, United Kingdom
Silver Member
Answered (Verified) Craig replied on Mon, Jan 30 2017 9:42 AM
Verified by ALF
Alf
I did manage to locate the mystery diode, see my basket case thread, don't know what it does however...just that it's there. It's probably not much comfort to you to discover that I have been able to sort my particular issue and can now get on with closing it out....It has also been a longer exercise than I expected at the start.....but very satisfying in the end....keep at it.
Craig
Søren Mexico
Mexico City
Verified by ALF
The DBT behavior is correct, it lights up briefly and then stays out if there are no shorts, it will stay on if there is a short and therewith protect the BM
Craig
Silver Member
Answered (Verified) Craig replied on Wed, Feb 1 2017 2:04 PM
Verified by ALF
Alf
Be sure to check the way the TIP'S are connected in each case, as Martin advises it is very easy to miss the fact that two have the connection wires crossed over and not in line like the others...see my basket case thread for the details, also the BD165 (OTR100) that I fitted needed to be installed "face to heat sink" as the pins where opposite to the one I removed.
Søren Mexico
Mexico City
Verified by ALF
Craig
Silver Member
Verified by ALF
Alf
ALF
AUS
Silver Member
ALF replied on Thu, Feb 2 2017 8:13 AM
That's right
but
in case of a persisting short wouldn't we have the fault-switch, triggering the relay to cut the power to the power-amp section ??
If that is the case the DBT would certainly go dark again  ?!! And assuming the fault-switch is working correctly !!
Anyhow, that is how I understand it unless I got it wrong.
ALF
ALF
AUS
Silver Member
ALF replied on Thu, Feb 2 2017 12:28 PM
Hi Craig,
Not quite sure I follow ??
I mounted both BD-139 - my replacement for the BD165 - with face up as it should.
Is the marking on the board wrong or is it because the marking/ wires are just the opposite to the BDs pins ??
It should be no problem of crossing those short brown wires towards the pins of the BDs ?!
Please tell me if I am missing the point here ?
ALF
ALF
AUS
Silver Member
ALF replied on Fri, Feb 3 2017 3:32 AM
Yes, assuming the fault-switch works
But there could be a short somewhere other than in the power-amp-section:-):-)
I guess in that case the DBT would have to light up  !?!
ALF
Page 2 of 2 (20 items) < Previous 1 2 | RSS
