BeoRemote One with Beovision 10 (46)
Answered (Verified) This post has 1 verified answer | 9 Replies | 2 Followers
hob
hob posted on Wed, Jan 11 2017 4:22 PM
Hi all
Sorry if this is obvious, but google brought up confusing info: Does the BeoRemote One work with Beovision 10-46 TV?
Best
H
mr_anders_son
sweden
Verified by hob
hob:
Hi all
Best
H
Yes it does!
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 2xHDMI....BV7-32 MK3....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
mr_anders_son
sweden
Verified by hob
hob:
Hi all
Best
H
Yes it does!
StKong
Copenhagen
Silver Member
StKong replied on Wed, Jan 11 2017 4:56 PM
I, too, am confused. Is there a dedicated BT and a dedicated IR version of the BeoRemote One?
Is B&O phasing out infra-red controlling? I have heard that BT-controlled products, such as the Essence, do not operate as smoothly as one is used to with the ordinary remotes.
Millemissen
Flensborg, Denmark
Yes the new ones - the BT ones - are the only remotes, that can be used with the new BV's.
Actually the two are quite different!
I suppose, that they are phasing out ir (the BT version of the BROne though, has ir-modes as well).
Time will tell - at least when the LL/B&O-tv are coming, we will know.
StKong
Copenhagen
Silver Member
StKong replied on Thu, Jan 12 2017 12:18 PM
I am about to install several IR-eyes in with Essence units. I don't have much need for TV's but am of course interested in what the future will hold.
The IR-eyes attach to network cables, so I gather it should be possible to upgrade in case of an all-BT future.
hob
hob replied on Tue, Jan 17 2017 12:14 PM
Thanks, yes it does work :-)
Millemissen
Flensborg, Denmark
StKong:
In case there will be a future update for controlling the Essence boxes, I am sure that you will need the BT version of the BROne....
....and you won't need an eye/receiver for that - it will be paired directly with the box.
If you are not in a hurry, you - maybe - should wait for that update (my guess is, that it will come soon).
Why not let your dealer contact Struer for a (possible) answer to 'if and when'!
Would be a bit too much efford to install ir-eyes and cables, that you maybe won't need in the (near) future.
On the other hand, if you already have some ir-Beo's, it might be ok so  - although, I expect that you will have more commands at hand with a BT-based remote control solution.
StKong
Copenhagen
Silver Member
StKong replied on Tue, Jan 17 2017 1:35 PM
Millemissen:
Thanks, again MM. With several Essences hidden away in a tech room, I think the cabled version is difficult to avoid, but I will follow the development closely. I imagine the end-eye may one day become BT.
With regards to dealerships in the Copenhagen area and their knowledge of Multiroom-installations I have yet to be impressed. Unsure
Millemissen
Flensborg, Denmark
StKong:
And I can hardly imagine an external BT-eye!
On the other hand - B&O have to think about something for this kind of hidden installation.
Did you already try to connect a 'wheely' via bluetooth.
If yes and the distance is too big - why not write Struer and ask what to do (with your hidden boxes).
(I guess the problem will be the same whether you use a 'wheely' or a BT/BeoRemote.)
StKong
Copenhagen
Silver Member
StKong replied on Wed, Jan 18 2017 7:00 AM
Millemissen:
But the BT remote has infrared as well, so there is no problem with the current link eyes.
Page 1 of 1 (10 items) | RSS
