Beovision 5 (non HD) and Amazon Fire TV
Not Answered This post has 0 verified answers | 2 Replies | 1 Follower
alvinedyvane
Portsmouth
Silver Member
alvinedyvane posted on Tue, Jan 10 2017 10:35 PM
Hi all. I have had the Beivision 5 unit for some time now and have experienced the frustrations of tech moving with the times. I have used Apple TV via a Keene scart converter for example for years.
But recently I decided to give the Amazon Fire TV a whirl but even via a HD video converter I seem to struggle to get it to work.
is anyone else succeeding with this?
Am I using the right or wrong converter?
thanks
alvin
kallasr
Germany
So the apple tv hdmi connection via the scart converter works, the fire tv one not?
Did you try to set the resolution of the fire tv to 720p (using a minitor or other tv set with hdmi input)?
I used an active hdmi to s-video converter from ligawo to connect a fire tv stick to a Loewe CRT.
So there is a solution for you for sure.
Ralf
Beosystem 4 with Beolab 7-6 on table stand (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Sony 55W905A. BeoVision 4-50 HD ready (D9) with Beosystem 3 MK I with Beolab 7-2 on table stand (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Sony VPL-HW55 projector for cinema mode. Beosound 9000 MK3 on horizontal wall bracket. Beosystem 7000 with Beolab 5000 Speakers. Loewe TV with Beolab 6002 and Beolab 11 (all white). Beocenter 6-26 white on motorised stand. In storage: Beolab 5000/Beomaster 5000.
simon8201
Devon
I use one of these connected to the side panel (composite connections)
http://www.amazon.co.uk/gp/product/B00NGHAPBI?keywords=hdmi%20converter&qid=1457688578&ref_=sr_1_3&sr=8-3
I notice it's listed as currently unavailable, but there must be something v similar out there. I use it for my amazon fire stick and it works well. I do get a bit of a 'buzz' at high volume but otherwise it's good! The problem I had when I installed it was picture and no sound-it was solved by connecting the box to the mains electricity by the included usb adapter plug. So far, it's worked well enough for me to hold of purchasing a newer Beovision!
Page 1 of 1 (3 items) | RSS
