Click here to tell us about your new email address
Problems with Beovision 7-55
Not Answered This post has 0 verified answers | 26 Replies | 0 Followers
Milo16
Milo16 posted on Tue, Jan 10 2017 5:33 PM
Hello everyone,
I have a problem with Beovision 7-55 Type No. 7724. The TV has stayed off for 2 years. Wen Turn on ask for the pin and I have tried to put the pin but after put the pin and GO button nothing happen display stay  the same , I have contact B&O and took the master-code from them put the master code and GO button. but the same situation as with Pin. (see picture attached)
Thanks in advance
stefan
200 miles from Struer
stefan replied on Wed, Jan 11 2017 8:26 PM
9 LEE:
MM is right.  If the TV has been set up for Beo5, Beo6 or the Beo4 Navigation the 'GO' command is different to that of a 'normal' Beo4.
So, with a standard Beo4 you can do everything right up to the point you need to confirm a command with the GO button, then nothing happens...  This is the reason that in the set-up menu you can choose 'Navigation Button' or 'No Navigation Button'
I'm not aware of a way round this, but someone may know.  Once you're 'in' and past the PIN Code you can change the setting to 'No Navigation Button' and use your current remote though...  My only suggestion is to borrow a Beo4 Navigation for now.
Lee
Sorry, I didn`t read the whole thread, but if you need the "old" GO button, and you have the Beo4 navi, then just use the PLAY button instead of the SELECT button.
Stefan
kallasr
Germany
If this works someone should send you a bottle of red wine Big Smile
Ralf
Beovision 7-40 MK III on motorised stand with Beolab 7-2. Beosystem 7000 black on driving Beolab 5000s (flat panel), remote: Beolink 1000 + Beo 4 DTV. Beosystem 3 MK I with Beolab 7-2 on table stand (Center), Beolab 8000 (Fronts), Beolab 4000 (Rears) and a DeToma B800 active subwoofer - Screen: Sony 55W905A. TV on/off controlled by Lintronic TT455-238 with IR Eye. Beosound 9000 MK3 on stand plus Sonos ZP90 masterlinked to Beosystem 3. White Beosystem 6500 with Beovox Cona + Beovox CX100 white. Kids' room: BeoVision 4-50 HD ready (black Frame/2 x DVI) with Beosystem 2 HD ready with Beolab 7-2 plus cabinet. Beovision 7-32 MK III on motorised table stand with Beolab 7-1. In storage: Beolab 5000/Beomaster 5000. NSM 3101 100 x CD changer almost ready to be setup since October 2015...
Milo16
Sorry, remote beo4
Milo16
Milo16 replied on Wed, Jan 11 2017 10:19 PM
I have confirmed to first coment that is beo4
Seanie_230
UK
Try putting in the PIN number and pressing stop
BLGW - Rekindling the love of ML
Millemissen
Flensborg, Denmark
ONLINE
And that is the one, that originally/2 years ago was used with the tv?
kallasr
Germany
kallasr replied on Wed, Jan 11 2017 10:23 PM
I can smell the bouquet....
Milo16
Milo16 replied on Thu, Jan 12 2017 9:52 AM
Yes the same
Milo16
Milo16 replied on Thu, Jan 12 2017 9:53 AM
:) you think that I have not try...
stefan
stefan replied on Thu, Jan 12 2017 4:14 PM
So maybe /obviously your BV7 is assigned to Beo4 with navigation button (that`s usually the case with a BV7-55).
Press MENU on your (older) Beo4 and search for something like "Remote Conrol" or whatever it is in your language. You can switch between Beo4
- with navigation button
- without navigation button.
Switch to "without..."
Stefan
9 LEE
Eastbourne, UK
9 LEE replied on Thu, Jan 12 2017 7:56 PM
stefan:
Stefan
He can't get past the PIN Code entry Stefan - that's the issue...
He needs a Navigation Beo4 to get the TV to accept the PIN/Master Code - then he can change it to 'No Navigation Button'
Until he can get past the PIN entry, he's stuck!
Lee
Millemissen
Flensborg, Denmark
ONLINE
When you try to help remotely on the forum, you always need precise informations!
After all, that I understand the tv (somehow) is set to navigation with the Beo4-joystick.
I have no further suggetions, than to get a Beo4/navi - set to mode 1 - and to try this out.
http://bogo.custhelp.com/app/answers/detail/a_id/3757/~/which-mode-must-i-use-on-my-beo4-remote-control-with-navigation-button%3F
Page 2 of 2 (27 items) < Previous 1 2 | RSS
