Click here to tell us about your new email address
MS150.2 Tweeter WANTED
This post has 12 Replies | 0 Followers
Cooker
Posts 110
Cooker Posted: Sat, Dec 10 2016 10:01 PM
Hi all,
I purchased a pair of lovely MS150.2 and the tweeter on one of them has been replaced with a non genuine one and it is making some fuzzy noises! The tweeter in reference, is the larger silver dome one, second from the top. Does any one have one I could buy or know what is the exact equivalent I can replace it with (would prefer 100% original).
Regards.
Cooker
Posts 110
Cooker replied on Mon, Dec 12 2016 11:09 PM
The speaker im after is the midrange 3" dome unit and I think it is a SEAS H226. Is it the same for MS150 and 150.2?
Anyne who has a spare one would be greatly appreciated.
AdamS
Posts 147
AdamS replied on Tue, Dec 13 2016 1:18 PM
Do be aware that the midrange drivers are different on the MS150 and MS150.2. The MS150 driver has a clear dome and is part number 8480146 but the MS150.2 has a black, sticky dome and is part number 8480160.
Martin (user 'Dillen') often has them in stock on his Beoparts website and I can personally vouch for the quality of the parts he provides and his excellent service, as I had to buy a new driver from my own MS150.2s earlier this year. It looks like he has none in stock at the moment but it's worth keeping an eye out or sending him a message.
Cooker
Posts 110
Cooker replied on Wed, Dec 14 2016 10:46 PM
I have been trying to contact Martin for awhile but no response. Thanks for the info about the differences in midrange 3" speakers. I thought there was some differences between 150 & 150.2. Ok, so basically one of my MS150.2 has a silver dome and the other has a black sticky one. The black sticky one makes a "fuzzy" noise during operation. So would I need two new midrange speakers then? One to replace the bad sounding one and another to replace the silver dome one fitted in the other speaker? Thanks
AdamS
Posts 147
AdamS replied on Thu, Dec 15 2016 1:11 PM
Yes, it sounds like you'll need two of the correct unit.
As an aside, my faulty midrange was making the same sort of noise and it turned out that the voice coil had literally fallen off the coil former. This is not something I've seen before in nearly 20 years of designing, building and repairing speakers!
Cooker
Posts 110
Cooker replied on Thu, Dec 15 2016 1:39 PM
Need Martin!!!!!!!
Dillen
Copenhagen / Denmark
Posts 9,313
Dillen replied on Thu, Dec 15 2016 2:29 PM
I can hardly post anymore. I keep getting timeouts. Quite annoying.
Carefully  take the driver apart (watch out for the very delicate wires, a bit tricky because of the sticky stuff used to hold the pieces together) .
Glue back the voicecoil to its ridge on the inside of the plastic dome using a small amount of 2-comp epoxy glue.
I use Araldite Standard (the blue slow setting one).
Typical symptoms are rattling, distortion or a completely silent midrange.
Cooker
Posts 110
Cooker replied on Thu, Dec 15 2016 9:59 PM
Thanks Martin,
Do you have any spares? Sent you an email last week.
Dillen
Posts 9,313
Dillen replied on Fri, Dec 16 2016 6:32 AM
None at present, I'm afraid.
Cooker
Posts 110
Cooker replied on Thu, Apr 27 2017 8:32 AM
Hi all,
Still chasing mid range unit 8480160
Does anyone have one, or preferably two?
Cooker
Posts 110
Cooker replied on Thu, Apr 27 2017 11:43 PM
Does anyone know what other Beovox uses this same midrange driver?
sonavor
Texas, United States
Posts 2,675
sonavor replied on Fri, Apr 28 2017 1:58 AM
Do you mean the one as pictured towards the bottom of this page? If so then it might be repairable as one of mine was in that referenced MS150 thread. The repair I showed there has held up now for five years and counting.
-sonavor
Cooker
Posts 110
Cooker replied on Fri, Apr 28 2017 11:57 AM
No, I'm after the MS150.2 version with the sticky black Dome, not the opaque Dome.
I need at least one, as someone has fitted an MS150 opaque dome midrange to one of my MS150.2.
Page 1 of 1 (13 items) | RSS
