LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 08-20-2008 4:15 AM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 08-19-2008 8:04 PM
    External tone connection
    on my Beocenter 7700 there is a 4 pin din "Line" socket to connect an equalizer,tone filter or noise reduction unit.Is this a standard 4 pin din or does it require the special cable suggested in the user manual (cable 6270215) ?
  • 08-20-2008 4:15 AM In reply to
    Re: External tone connection
    Pretty standard in and out. Pin 2 is the common earth. I attach the bit of the circuit diagram.
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
