LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 10-01-2008 2:49 PM by JohnC. 8 replies.
Page 1 of 1 (9 items)
  • 08-19-2008 5:45 PM
    • JohnC
    • Not Ranked
    • Joined on 08-19-2008
    • Posts 6
    AV9000 TV
    The TV has stopped working in that it appears to be on standby but when the remote selects TV the sensor blips green for a fraction of a second and reverts to red. Just happened.......Any ideas please.
    Whilst thinking of this point, can I raise another matter, wholly unrelated. Somewhile back the video has taken in a tape, correctly so far as I can tell but it will not run nor will it eject it. In effect the Video is dead. Any thoughts
  • 08-20-2008 5:19 AM In reply to
    Re: AV9000 TV
    Sounds like a component failure which is preventing the correct start up of the TV.
    I am in Farnham, Surrey, UK if you are close by and would like me to take a look for you.
    Neil
  • 08-20-2008 10:50 AM In reply to
    • JohnC
    • Not Ranked
    • Posts 6
    Re: AV9000 TV
    Nobby.......have we met?...are you just of the Farnborough Rd at Heath End?......we may have done a deal on some speakers via Ebay somewhile back
    John
  • 08-20-2008 12:36 PM In reply to
    Re: AV9000 TV
    Yes, indeed.
  • 08-20-2008 2:43 PM In reply to
    • JohnC
    • Not Ranked
    • Posts 6
    Re: AV9000 TV
    Hello again
    As you may know I'm over in Tadworth in Surrey....so a bit of a trek
    My local repairer is saying the fault is perhaps an indication of a protection circuit control activating to prevent component damage......and there can be a number of these.
    so, somewhat of a challenge
    John
  • 08-21-2008 9:27 AM In reply to
    Re: AV9000 TV
    OK, let me know ... but unless you know what you are doing around a tv, I would not attempt a fix yourself.
    Neil
  • 10-01-2008 11:59 AM In reply to
    • JohnC
    • Not Ranked
    • Posts 6
    Re: AV9000 TV
    Neil.......I have the AV9000 in its two parts and with a colleague and van can drop it over to you should you still be happy to have a look at it for me.......
    We have some jobs to do over in Friars Court Heath End so that would be a good time to call in..............next week i guess
     can you give me a mobile no........ kind regards
    John
  • 10-01-2008 12:14 PM In reply to
    Re: AV9000 TV
    I would suggest that you chat re PM or your number will soon be public knowledge! Laughing
    I have left it for now but suggest you remove it!
  • 10-01-2008 2:49 PM In reply to
    • JohnC
    • Not Ranked
    • Posts 6
    Re: AV9000 TV
    very prudent ...thanks for the heads up Wink
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
