LifeStyle AV - Pre-owned Bang & Olufsen you can trustClick HERE to tell us about your new E-mail address
Latest post 12-18-2008 5:35 PM by Karel Uyttendaele. 4 replies.
Page 1 of 1 (5 items)
  • 07-09-2008 7:14 AM
    • Bulgarien
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Denmark, Vest Sjaeland
    • Posts 201
    Earset 1 wiring/plug for SKYPE, help
    Does anybody know the wiring in a Earset 1 headphone
    All headset to SKYPE are big, ugly and in cheep plastic  and therefore we will use the great Earset1 as a  headset to Skype chat, but I need to change the plug,
    Therefore I need a wiring diagram.
    There is four wires total; green and green/red together (for one unit -microphone?) and red/cobber together  f(or the second unit- speaker?)
    Which wirepart is for microphone and for speaker
     What kind of  plug do I need for my computer/skype?
    Not only for our mobile, but olso for Skype
  • 07-09-2008 1:14 PM In reply to
    Re: Earset 1 wiring/plug for SKYPE, help
    I am very intrested to know the wiring diagram too.
  • 07-09-2008 9:45 PM In reply to
    I travel a lot and to keep touch with the family, I use Skype overseas alot.
    I use the following combination:-
    The Earset 1 (mobile)
    A Stereo 2.5mm to 3.5mm adapter (Maplins for a quid)
    A 3.5mm Stereo to two 3.5mm mono adapter (aircraft adapter - again Maplins for a quid)
    This final adapter just squeezes into most laptop mic/output sockets. I could be rationalised further but a) I'm not a good solderer and b) yon need two lose plugs whereas the solution above keeps the equipment as standard.
    10%
  • 12-18-2008 3:00 PM In reply to
    I tried exactly that, from maplins. I can hear audio, but the mic does not seem work ... The volume seems very very low ... Any thoughts?
  • 12-18-2008 5:35 PM In reply to
    Unfortunatly I don't have a wiring scheme... but from what I saw it was straight forward... 2€ of pieces and 5min work by neighbor... works flawless!!!!!
    The race for quality has no finish line- so technically, it's more like a death march.
STB Brackets - Flexible Mounting Solutions for Bang & OlufsenHygge Living - Bang & Olufsen Installation SpecialistsNeed a cable? Just ask Steve at Sounds HeavenlyBeo 5 remote control programming service
